Hi guys,
on my 81 xs11 special
so I am not sure how, but my cam chain slipped on the gears and the bike went a 180 degrees out of time, and had no compression. After sitting for a couple of weeks I pulled the top end off, was checking my valve clearances, which were all off. In the process realized that i had several bent valves, assuming that it happened when the cam chain slipped, as it was making some serious clanging noises.
So i take the head over to my bike shop, and discovered that some of the valves are discontinued. Does anyone have a source for the valves aftermarket, or have a used set in good shape they are willing to part with?
I hope to replace the valves, get the head worked over, replace the cam chain and reshim the valves asap.
As always any help is greatly appreciated.
Thank you, Darrell
Thank you, Darrell
