As always, thanks in advance for all your help. You guys really offer great thoughts. If you see anything I should be aware of if other pictures would be interesting to you, please let me know.
Finally picked up the bike associated with the carbs I asked about in an earlier post.
Not sure how the engine got blacked out but, at some point, this bike was well taken care of. Tank is beautiful. No rips in the seat. New valves (7) and cam chain. New Avon Roadrunner tires. Wiring was re-fused but I will do it again with a fuse block and no glass fuses. Side covers are great and I have the clutch cover, etc.
Any thoughts re: why there is no shaft for the kick start? Do I need a part?
Tank looks clean but it has been treated. Does that look like Kreem or something else?
Pipes are pretty nice except that the back end of both look like below. Do you think they just rusted out or did the PO cut them out for some reason? Any thoughts on using them or how to cover the end?
Thanks again,
Doug
Thanks again,
Doug
You need to check the frame and motor numbers to see what you have. The motor is a '80 or '81, due to the lack of a kickstart shaft (unless somebody has changed the cover and removed the shaft). Rear footpeg supports are off a '81, and the taillight is a standard unit. The mufflers, somebody cut the ends out (more noise), that might be repairable if you can find some junk mufflers for parts. Missing the seat grabrail. But it looks like you have all the important stuff..
