Strange action on rear turn signal
  • #16
    found problem
    found problem with turn signal. ..socket was totaly corroded underneath. I saw the rust inside socket and cleaned it. What I failed to see and clean was the massive rust that was at the bottom of the socket when you push the bulb in. I had taken bulb out and cleaned and forgot about the spring action when bulb is set. Pushed in spring area, cleaned rust and ground straps and viola, works perfect.
    Now, another problem. the turn signals are set up with dual filaments as running and signal lights. I understand this is not legal in PA. mUST THEY BE RED LNSES? If so, where can they be purchased> Thanks for the help.
    1980 xs1100g
    • #17
      Does the running light actually work properly?
      Don't know about the rectangle red lenses, but until you find them you could just unplug the running light wire.
      • #18
        To be legal, they gotta be red...
        You can get them here: http://www.crc2onlinecatalog.com/turn_lens.htm
        • #19
          yes, they work correctly
          1980 xs1100g
          • #20
            Thanks for info. I'm gonna order them. Alot cheaper than what the ticket would cost!
            1980 xs1100g
            • #21
              Just remember its only the rear that needs to red and not the front. You cannot have red lights facing forward, that is reserved for emergency vehicles only.
