ok so i saw that on a xs the rakes 29 degrees anyone know the length of the tube that holds the forks. i know i cant just measure the tube
frame specs ?
Tags: None
If you're trying to do a rake/trail calculation, the 'fork length' is the distance from the centerline of the axle to the top of the fork neck. You should come up with a distance of about 30.5".
If you have leading-axle Special forks, you need to figure the distance between the centerlines of the fork tube and axle and add that figure to your triple tree offset.
The stock rake number is 29.5 degrees, and trail is 5.12". This is the same for all models; while the Special forks are different, the effective geometry is the same.
You want to be careful swapping/mixing parts between the standard and special forks as this will affect your trail number.Last edited by crazy steve; 03-11-2011, 08:11 AM.Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
Which tube?
Hi enthusiest,
would that be the tube that's welded into the frame or the tube that's inside it that joins the triple trees together or the tubes that clamp into the 'trees that the fork lowers slide on?
Um, so what are you up to, eh?Fred Hill, S'toon
"The Flying Pumpkin"Comment
found a diff kinda fork
found a diffrent kind of fork that can be made to fit the length bike need the rake and the tube length that holds front end togetherComment
