Mono Shock??
  • chpzenker
    • Nov 2010
    • 18
    • South East Texas
    Mono Shock??
    Has anyone contemplated putting a single mono shock vs. the two coil over’s on an xs1100?
    • 7831
    If you do a "search", I think you will find at least two threads. Make the time at least two years, though.
      It's been done by several forum members, but requires some pretty extensive mods. The OEM swingarm isn't stout enough, so you're talking a new and/or heavily modded swingarm, maybe a new rear wheel/brake, and sometimes (always?) a conversion to chain drive. Do a search for 'mono-shock' and 'swingarm mods'; you'll get lots of hits. Not easy, and usually not too cheap either.
      But it is doable...
        I recall there was a guy in the Phillipines that did a monoshock mod as well as an undertail exhaust mod. IIRC he kept the shaft drive at the same time, I don't remember what swingarm he used but it was off another yamaha.
        • petejw
          • 2269
          • sydney australia
          theres a cpl of guys on the uk site
          that have done the mono shock mod,
          heres a link to there site, youll have to do a search
          for it tho.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • petejw
            • 2269
            • sydney australia
            heres a link to toms rat bike
            using the stock swing arm and rear wheel.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              A link (photos are gone) of an R! shock mounted on an XS.
              Pat Kelly
              <p-lkelly@sbcglobal.net>
              1978 XS1100E (The Force)
              1980 XS1100LG (The Dark Side)
              1999 Suburban (The Ship)
              1994 Dodge Spirit (Son #1)
              1968 F100 (Valentine)
              • chpzenker
                • Nov 2010
                • 18
                • South East Texas
                After looking at all the other posts and facts i believe i will go some other route. thanks for all the great advice.
                • perurider
                  • Apr 2010
                  • 121
                  • Peru, Indiana
                  Theres a member who put the mono shock from an r1 on one side of his xs i cant remember his name his xs had airbrush work on the tank of a skeleton with a tophat then he turned it into a cafe racer. he has 'ford' in his screen namesomeone help me out he also bought a newer superhawk. I think i have an image on my computer ill look.
                  '79 XS 1100F
                  • Toolmaker Tim
                    • 671
                    • South Bend, Indiana
                    Mono shock swingarm
                    The guy in the Phillipines used a Virago swingarm. I remember seeing it recently. I don't know the dimensions of the pivot point of the XS11 vs. the Virago. It looked pretty neat though.
                    1979XS1100SF
                    K&N's and drilled airbox
                    Jardine 4in1
                    Dunlop Elite 3's
                    JBM slide diaphragms
                    142.5 main jets
                    45 pilot jets
                    T.C.'s fusebox & SOFA
                    750/850 FD mod.
                    XV 920 Needle Mod.
                    Venture Cam Chain Tensioner
                    • T99Ford
                      • 678
                      • Bozeman,MT
                      I ran the R1 shock for awhile, and it worked really well. Here is a link with pics of it on my bike (gen 2).
                      When I went the cafe racer route, I removed it since I wanted the look of dual rears again to be a little more style correct. The stock R1 shock was a little stiff for my weight (160#), when used on this swingarm geometry. It would fit a bigger guy really well. I didn't use XSchop's mounting method, though. I actually used the stock shock locations, and just modified bushings in the R1 shock to fit the stock mounting locations. If I remember correctly, only the top mounted needed modification. Beyond that, I did have to take a little material off the edge of the rebound reservoir, to ensure no tire contact. I ran this (hard) for about a year, and never had any flex or breakage issues with it, although I did watch it pretty closely. A pretty simple mod that leaves the LH side of the swingarm looking like it is floating--a pretty cool effect.
                      Healthy is merely the slowest rate at which you can die
                      Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I’ve always believed this, in spite of the trouble it’s caused me. Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba….Hunter S. Thompson
                      • danteinien
                        • Mar 2008
                        • 101
                        • Utah
                        Here's mine. I used a monoshock from an '08 R1.
                        (XS750/XS850, but, they are the same as the '11)
                        • roccet
                          • 102
                          • bend oregon
                          Yes mono shock.
                          Yes i have done it.. 2010 honda goldwing single arm Mono shock rear end.
                          a fair amount of prep work to make it work but its possible.
                          [IMG]http://s142.photobucket.com/albums/r90/tarmacsports/?action=view&current=IMG_5514.jpg [ /IMG]
                          i hope this pic shows up for some reason i am having problems getting my pics to show up.
                          1978 E XS1100 purchased for =$600.00
                          crap load of time spent modifying it = Priceless
                          My bike has the XS motor but can't really call it XS11
                          (or at least it still looks like the XS motor)
                          it has about 50% of the frame left from the XS bike
                          • roccet
                            • 102
                            • bend oregon
                            MONO and single side
                            ah there we go.
