petcock washers
  • Filter
  • petcock washers
    When reinstalling my petcocks, one of the fiber washers that goes between the screw and petcock broke apart. Is there somewhere I can get these besides a dealer, or replace them with some other type washer?
    Robert
    79 SF
  • #2
    I got 4 new ones myself from bikebandit at a somewhat reasonable price. They now list 78/79 XS11's in addition to 80/81s they listed before.
    Dont try using a normal metal washer or a nylon washer, they might work for a little while, but you'll be sorry you used them in not too much time.
    • #3
      Hey there Rob,
      I've seen felt washers at my local hardware store. When I did my relining of my tank, mine were junk, but I went and used some neoprene type rubber washers on mine, been there for 2 years+ and no leaks so far!!
      • #4
        Robert, my Kawasaki uses nylon ones, instead of the fiber disks. I picked up some at Home Depot and they work great.
        Brian
        remembering the same thing!
        • #5
          Just another quick note about the nylon washers : I used a set a few years ago, they lasted about 2 years until I took the petcocks off to rebuild them, and the darn things pretty much disintegrated. No leaks or anything up to that point.
          • #6
            Petcock washers
            Are you talking about those that are the screws?What I did since my luck with things like that are, they will leak,is get a tube of Permatex-2 form a gasket sealant{non-hardening pliable sealant}.Worked real good on my tank,didn`t leak.The good thing about this stuff is,can take the parts off no problem.I put a thin bead all the way around the petcock where rubber o-ring is and some on the screws,tighten down good will see some excess on out side easy to cleanup.Hope this helps.
            Bill Harvell
            • #7
              I did the same thing, I used Permatex, no leaks, in last month. Later 'Dog
