Carburettor diagnostic tool
  • Steptoe
    • 175
    • Thabeban,Bundaberg QLD , Australia
    for those of us that have niggling issues,, { which is all of us }
    a simple, small home made tool to help
    never ride faster than your gaurdian angel
    can fly
    1981 rh 5N5
    MIDNIGHTSPECIAL
    1188cc
    4 into 1 pipes with a transac muffler,
    as the motorcycling gods intended everything else stock std
    http://s856.photobucket.com/home/steptoexs11
    http://steptoexs11.webs.com/
    http://www.youtube.com/my_videos?feature=mhum
    1982 vf750 sabre
    good idea for the late model carbs...........ought to fix the enrichment lever though...would make it easier for cold starts....
    • Steptoe
      • 175
      enrichment lever
      yep,, should do , don't need it tho,
      don't get cold enough here for cold starts
      will have to get round to it,
      can fly
      1981 rh 5N5
      MIDNIGHTSPECIAL
      1188cc
      1982 vf750 sabre
        Thanks for this, Steptoe, I've been meaning to build something like it to quickly check the fuel levels so I don't have to dance the carburetor removal/float-height tango.
        How is the tee-tree attached to the carbs? I can't quite see it in the video, is it just hanging on the edge of the carburetor by a piece baling of wire/paper clip or something?
        My '80G doesn't have the float bowl drain screw and built-in hose nipple like the '81 XS and the XJ but someone found a metric plug with a hose nipple at NAPA that can temporarily replace the solid float bowl drain plug.
        So far I keep forgetting about the plugs and hoses entirely when I'm at NAPA or I forget the size so it's taken a lot more time to build one than it should.
        • Steptoe
          • 175
          all I used was a very thin / small { we call em } zippy tie,,,{ cable ties }
          don't know what you fella's call em in w/shop talk
          can fly
          1981 rh 5N5
          MIDNIGHTSPECIAL
          1188cc
          1982 vf750 sabre
            Zip ties. Thanks, mate!
            My eyes are not what they used to be. I should get one of those giant magnifying lenses like they used to make to put in front of the screen of the old small-screen televisions.
