I have an unusual setup for the rear lights. The PO drilled holes in the brake housing and put in running lights.
The running lights have a single wire to the bulb seat.
The Turn signals are in there original place attached to the frame with their respective wires running to proper locations (i.e. not tapped into the brake wires).
Im currently cleaning up the POs wire mess in the brake housing and thought Id ask if this is going to explode when I turn the key.
PO had 3 wires wrapped around 3 different bolts (attempt to ground?).
Should I ground running lights to fender? If so, how and where do I put it?
