hooked up a new set today on my xj and is only firing on #2,#1 #3 #4 are wet. where did i go wrong. thanks in advance
dyna coils
Tags: None
It is starting and running though? If so I would first look and make sure all the plug wire connections are good and then I would move to the carbs. How was it running prior to the coil swap.Nathan
Theodore Roosevelt -
If its not starting I am with davinci.Nathan
Theodore RooseveltComment
I did the same thing with my Accels when I first plugged them in. I just swapped the plug wires from one coil to the other, and it fired right up.1980 XS850SG - Sold
-H. FordComment
dyna coils
what about fouled plugs? i hooked red white orange left side,#1#4, red white gray right side#2#3 is that right?Comment
Give your plugs a good cleaning and start it up again.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
You should state your model and yr in your signature. If you have late model 80/81 carbs then you might want to go one more turn out on the idle jet screws.BDF Special
BDF Special
Umm, more turns out is richer. Turned in is leaner, turned out is richer, these are fuel mixture screws not air mixture screws. Easy way to tell which they are, if they are between the diaphragm and the engine it's fuel, if they are on the other side of the diaphragm/ main jets it's air. Air gets leaner as you open them, fuel gets richer as you open them.Cy
Umm, more turns out is richer. Turned in is leaner, turned out is richer, these are fuel mixture screws not air mixture screws. Easy way to tell which they are, if they are between the diaphragm and the engine it's fuel, if they are on the other side of the diaphragm/ main jets it's air. Air gets leaner as you open them, fuel gets richer as you open them.BDF Special
