Dropped the chain
  • olatheracer
    • Apr 2010
    • 9
    Dropped the chain
    While taking apart engine to pull it, dropped the cam chain in.
    Anything to be aware of while taking the rest of it apart?
    Hey Ola,
    Depends on how far you are going to be taking things apart.
    Are you going to be pulling the head, jugs, splitting the cases???
    Do you have a manual to go by?? The teardown is documented in it.
    • mro
      • 4276
      • Hayward, California
      I've managed to do that.
      If your not pulling the head and cylinders then this will get it out.
      Some have had success with a magnet.
      • tcoop
        • Nov 2009
        • 793
        • South Weber, UT
        I just used a wire coat hanger. Woorked good for me when I dropped mine.
        Ty
        78 XS1100E - Now in Minnesota
        80 XS1100LG - The Punisher
        82 XJ1100 - Daughter's Bike
        • clcorbin
          • Jan 2010
          • 495
          • Albuquerque, NM
          Similar. I just used a piece of stiff wire (stainless safety wrap wire) with a small hook bent into the end. Worked like a charm!
          -- Clint
          • planedick
            • Mar 2005
            • 2068
            • Yorba Linda, California
            Remember
            It's pretty easy to not have the chain on the teeth on the crank when reassembling. Turning it over this way is a disaster.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
            • clcorbin
              • Jan 2010
              • 495
              • Albuquerque, NM
              True. But I wouldn't call it a disaster so much as a chance to replace some of your intake and exhaust valves. Probably three of them...
              On the bright side, it is VERY easy to verify that the chain IS fully on the teeth.
              -- Clint
