Front fork parts
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    Front fork parts
    I am looking for the rubbers that go above and below the headlight ears on a 1980 MNS. Can't find them available, and i thought maybe someone had used something else i place. It looks like a thermostat gasket like the one for the gas cap would work, but it was not quite thick enough. Any ideas? If there is somewhere to buy them new, i will.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    You're probably not going to find those rubber rings new anywhere. What I would do is find some type of rubber/vinyl hose the right diameter and carefully slice off a piece the correct length, HTH
      Try a hydraulics place for some extra-large o-rings. Those are just anti-rattle bushings anyway....
      • Rickrod3
        • Jun 2009
        • 721
        • Oakland, New Jersey
        On a standard I used plumbing slip nut washers.
        The black neoprene ones size 1-1/2"
        Any hardware store should have them.
        Not sure if the special forks are a different diameter but probably worth a shot.
        HTH
        Rick
        650SF
        XS1100SG Project bike
        • XS1100 Newbie
          • Jun 2009
          • 1106
          Thanks guys. I was thinking of o-rings, but had not thought about the plumbing end.
            My wife always wonders how I can go to a hardware store and just need one thing and then spend an hour there and still only come out with that one thing. Ya gotta look at what things could be used for not just what they are SUPPOSED to be used for!
            • tom clisham
              • Sep 2010
              • 627
              • Northern Illinois
              Damn Nate you got that right. I spent an hour today @ Menards looking for pieces I could use ( or bend, or drill, etc) to make hangers for my hard bags.
              Think I've got it figured.
              Tom Clisham
              Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
              _____________________________________________
              '78xs1100E ,all stock & original GONE TO WISCONSIN
              '80 SG Vetter fairing,hard bags,trunk,fork brace,
              stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
              79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
              79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                I just picked up a set of ammo cans to use as bags and need to concoct something up to use for brackets, you should keep up, or at least me, on what you for mounts.
                  Hi Newbie,
                  good luck finding new ones!
                  What you could try is finding the right size TetraSeals, (essentially, they are square o-rings)
                  A competent seal and bearing retailer should be able to find them for you.
                  • XS1100 Newbie
                    • Jun 2009
                    • 1106
                    I used an o-ring below the cover plate, and a sink rubber above. The combination worked great.
