Lock Lube
    Lock Lube
    What do use to keep your locks and ignition working and moving well?
  • XSive_speed
    • Nov 2010
    • 45
    • Cedar Rapids, IA
    I've always used dry graphite powder. It lubricates well and won't stiffen up in cold temperatures. Should be able to get it at the hardware store, or maybe someplace where they cut keys.
    John (XSive_Speed)
    '80 XS1100G Standard
    - 4 - 1 exhaust (probably Mac)
    - UNI air filter
    • ManagerMike
      • Mar 2010
      • 445
      • S.E. Michigan
      There is also a product called 'lock eaze' used for de-iceing locks. Look for the version of it "with graphite". The alcohol carries graphite powder in with it, gets deeper inside, and leaves the dry graphite behind when the alchohol evaporates.
      '78 E "Stormbringer"
      • CatatonicBug
        • 6117
        • Clinton, UT
        I opened mine up and took it all apart. Cleaned all the contacts and used dielectric grease on them. Graphite is common, but won't get rid of existing corrosion.
        • ManagerMike
          • Mar 2010
          • 445
          • S.E. Michigan
          I do believe he was asking about the mechanical aspect of the ign switch (tumblers and body) as opposed to the elecrtrical contacts. He mentioned "locks and ignition".
          What say ye Nate?
          • XS1100 Newbie
            • Jun 2009
            • 1106
            • Battle Ground, Washington
            Keep in mind that if you use a liquid lube of any kind, it will attract and hold dirt, and cause wear. The dry graphite is the best.
            1980 XS1100LG Midnight
            1991 Honda CBR1000F Hurricane
            A cold beer and another one!
              You got it Mike! I have taken it all apart and cleaned it but now since it is clean everything is dry and tight.
                A little bit of graphite as mentioned will do wonders for that. I won't mention any other products for problems of that kind, being married to an MD you should already be aware of those.
                  You would go there wouldn't you Cy.....
                    You KNOW I couldn't resist didn't you?
