This is a problem for many, as the plastic Yamaha used doesn't weather well. They never sold these as separate parts either (only available with the complete unit), so you have to live with what you have usually. Can they be made to look better? Well, judge for yourself...
Typical weathered reservoir; dried out, pebbly finish that holds dirt...
[IMG]
[/IMG]
There's not much you can do to bring the plastic back to life, so I block-sanded this until smooth and most of the weather checking was gone. Couldn't do anything with the 'low' window, so I left that. I started with 400 grit, then finished with 600. Looks better, but it's still got a dull finish.
[IMG]
[/IMG]
To give it a 'shine' and seal it, I sprayed some clear enamel over it. Yes, I know brake fluid will damage this, but it will still seal the plastic and will take a coat of protective wax.
[IMG]
[/IMG]
Doesn't look like a new one but does look better IMO, and is a cheap fix.
[IMG]
[/IMG]There's not much you can do to bring the plastic back to life, so I block-sanded this until smooth and most of the weather checking was gone. Couldn't do anything with the 'low' window, so I left that. I started with 400 grit, then finished with 600. Looks better, but it's still got a dull finish.
[IMG]
[/IMG]To give it a 'shine' and seal it, I sprayed some clear enamel over it. Yes, I know brake fluid will damage this, but it will still seal the plastic and will take a coat of protective wax.
[IMG]
[/IMG]Doesn't look like a new one but does look better IMO, and is a cheap fix.
[/IMG]
[/IMG]
[/IMG]
Did you consider working up to 1000 grit or so, then going to plastic polish? Just a thought.
more work to do this Spring!
