'Restoring' the Plastic M/C Reservoir
    This is a problem for many, as the plastic Yamaha used doesn't weather well. They never sold these as separate parts either (only available with the complete unit), so you have to live with what you have usually. Can they be made to look better? Well, judge for yourself...
    Typical weathered reservoir; dried out, pebbly finish that holds dirt...
    [IMG][/IMG]
    There's not much you can do to bring the plastic back to life, so I block-sanded this until smooth and most of the weather checking was gone. Couldn't do anything with the 'low' window, so I left that. I started with 400 grit, then finished with 600. Looks better, but it's still got a dull finish.
    [IMG][/IMG]
    To give it a 'shine' and seal it, I sprayed some clear enamel over it. Yes, I know brake fluid will damage this, but it will still seal the plastic and will take a coat of protective wax.
    [IMG][/IMG]
    Doesn't look like a new one but does look better IMO, and is a cheap fix.
    Just don't spill brake fluid on it and the paint will stay good!
    I was wondering if sanding would help that thing.
    Got a question. Anyone have any ideas for reattatching the little brass threaded bushings that are in there for the cap screws?
    • trdriver71
      • 360
      • Edmonton Alberta
      [IMG][/IMG]
      [IMG][/IMG]
      [IMG][/IMG]
      Doesn't look like new a new one but does look better IMO, and is a cheap fix.
      That is exactly how mine looks!!!
      '79 XS11SF
      • foreda
        • 949
        • Southwest Louisiana
        Rez
        Steve
        Now that you have it looking good..Send it to me!!
        78 XS1100E Standard
        Coca Cola Red
        Hooker Headers
        1979 XS1100 Special
        1980 XS Standard
        2006 Roadstar Warrior
          Originally posted by natemoen
          ..Got a question. Anyone have any ideas for reattatching the little brass threaded bushings that are in there for the cap screws?
          That's only on the '78-79 standard master cylinders, and they're not supposed to come out. If yours came out, you'll either have to find another '78-79 reservoir, another whole M/C, or somehow glue yours back into place.
          The '80-81 standards attached the reservoir with the caps screws, as did all the specials. You can't interchange the two types of reservoirs...
            That's only on the '78-79 standard master cylinders, and they're not suppotsed to come out. If yours came out, you'll either have to find another '78-79 reservoir, another whole M/C, or somehow glue yours back into place.
            Tried JB weld, alas it gets awful soft and useless if it gets brake fluid on it. I have considered drilling and taping holes so that it screwed into the body like the later models, but haven't gotten up the nerve to drill holes in my mc yet. Got any close ups of the holes in yours?
              Nate, I'll send you a PM....
              • XSive_speed
                • Nov 2010
                • 45
                • Cedar Rapids, IA
                Looks good. Did you consider working up to 1000 grit or so, then going to plastic polish? Just a thought.
                I was thinking of trying something similar here, but before I do, I would rather have a backup plan. IIRC, somebody had some metal reservoirs, I think off an XJ or maybe it was the 650s, that would fit the XS MC. Can't seem to find the thread at the moment, but if I had one of those, I wouldn't mind experimenting with my plastics.
                John (XSive_Speed)
                '80 XS1100G Standard
                - 4 - 1 exhaust (probably Mac)
                - UNI air filter
                  Originally posted by XSive_speed
                  Looks good. Did you consider working up to 1000 grit or so, then going to plastic polish? Just a thought..
                  I looked at that, but the problem was the checking went pretty deep. You can't see it in the 'sanded' pic, but there's still some microscopic cracks that would be visible unless you sanded even more off. I didn't want to take too much off and change the shape. The clear paint 'filled' these and made nearly all of them disappear.
                  • petejw
                    • 2269
                    • sydney australia
                    my 81 model sport came with an alloy m/c,
                    could be the same on the mns but not sure.
                    steve, that came up well considering how it previously looked.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      The LH has the metal reservoir too. The LG didn't though. You can buy the whole metal setup from mike's though ($87).
                      • petejw
                        • 2269
                        • sydney australia
                        bug,
                        didnt the LH have the linked braking system?
                        my bike doesnt so it would be safe to say they'll
                        work with the dual front callipers.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                          more on the same subject
                            bug,
                            They have 2 versions. One for the single calipers, and one for the dual setup. Both on the same page.
                            • nzemke
                              • Sep 2012
                              • 179
                              • Moses Lake, Wash.
                              Have you looked at getting the part 3D printed?
                              79F with two parts bikes (78E and a 79F). Ran it for the first season all the way through the summer. more work to do this Spring!
