Advice on removing gasket material from intake rubbers
  • Lucky23
    • Feb 2011
    • 22
    • Portland, OR
    Anyone know of a safe way to remove old gasket material from the rubber intake manifolds? its stuck on pretty good and I dont want to damage the rubber...
  • Fireplug
    • Feb 2011
    • 23
    • Phoenix, AR
    A little bit of WD40 and a thumb workout might work for you. Should just kinda rub off.
    2005 Honda VTX 1300 c
    slightly custom
    1979 XS 1100 SF
    in the works
    1979 XS 1100F, or
    1978 XS 1100E
    parts bike
    1980 XS 1100 SG
    just sitting partly torn down by PO
    playing roll of parts bike for now
    Hate to break it to the purists here but I cant go for the whole stock thing on this one.
    • Lucky23
      • Feb 2011
      • 22
      • Portland, OR
      Yeah, thats what Im doing. Seems to be working.
      • Fireplug
        • Feb 2011
        • 23
        • Phoenix, AR
        Good deal. Glad to hear it
        slightly custom
        1979 XS 1100 SF
        in the works
        1979 XS 1100F, or
        1978 XS 1100E
        parts bike
        1980 XS 1100 SG
          Hey Lucky,
          Are you sure it's gasket material?? They/Yamaha didn't use gaskets until the XJ's. The boots have a metal inner layer for strength to bolt to the head. The rubber is very thin over the metal there, and with years/decades of wear, it gets hardened, cracks, peels, crumbles, etc.!
          SO...if after removing the "gasket" you are at the base metal, then it was that thin rubber layer that had heat/dry rotted. Folks have then used gaskets and even fuel resistant sealant to secure them to the head with an airtight seal!
          • petejw
            • 2269
            • sydney australia
            i stick a piece of wet and dry on a sheet
            of thick glass and rub the intakes on that
            itll keep the surface of the intake flat, then u can use
            rtv to seal it against the head.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
