Best way to decarbon an engine?
  • 11Rider
    • Aug 2010
    • 331
    Hola mi amigos. I know my bike has some carbon build-up because of a visual check and slightly high compression. I've been doing a lot of reasearch on the best way to decarbon an engine and from what I've seen, it could be narrowed down to three basic ways. 1. Run a high concentration of Sea Foam throught the engine (3/4 gall. of gas and 16 oz. of Sea Foam), 2. Spray some kind of solvent (Sea Foam, WD40, etc.) into the intake while the bike is running. 3. Spray water in the intake while the bike is running. Is there any consensus here on the "best" way?
    '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
    Purrs like a kitten, runs like a scalded cat
  • Tarheeltriple
    • Dec 2010
    • 52
    • Eastern NC
    I think that the best way to remove carbon is a 100 mile drive with a properly tuned engine.
    From time to time I do use 2 to 3 ounces of sea foam to a tank of gas.
    I am not a fan of large quantity of sea foam.
    A friend of mine “wingnut” used super strong sea foam mix once and it softened the “cream” in the tank and washed it in to the carbs coating the inside of the carbs making a real mess.
    Everything in moderation is the key.
    Salty dog
    Eastern NC
    XJ-1100 Naked Boy
      Never would have thought sea foam would do that. Something to remember I guess.
      • petejw
        • 2269
        • sydney australia
        you could try all those u have suggested,
        also Tarheeltriple makes a good point,
        but at the end of the day the best way to do it is to
        strip the top end apart and clean it, carbon
        gets built up in the exhaust ports, combustion chamber,
        tops of pistons, behind the piston rings.
        im doing this at the moment.
        also u want to determine why u have so much carbon
        built up, could be rings or valve stem oil seals.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          You won't get rid of much carbon with seafoam in the tank .You have to spray or pour it into the carbs while it is running ,shut it down right away and let it sit for 10 minutes or so and then run it good on the centre stand . Make sure you are outside and stand up wind of the exhuast it will get thick .
          BDF Special
            I've often used running water into the intake on other vehicles with really good success. It's what I was taught to do by my HS shop teacher. Engines we pulled down afterwards were really clean. Now one thing he told me was to make sure to not just shut it down as soon as your done, but to run it a bit to get oil back up to the upper cylinder areas.
            • petejw
              • 2269
              • sydney australia
              ive done it they way to cy,
              u just need to be careful of the amount
              of water u pour in, to much, it will bypass the rings
              and end up in the oil.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • Fireplug
                • Feb 2011
                • 23
                • Phoenix, AR
                Rider, Ive using Techron Concentrate Plus for the last couple of years in my Honda VTX which is also ,with pretty good results. The bottle only gives directions for an average vehicle so I figured it out to how many ounces for my tank and went from there. You should be able to find it at your favorite Auto parts store. Also if im not mistaken, there is a product similar but somewhat more expensive, sold at bike dealers. Whichever way you decide to use of all of these different ideas keep us posted .
                2005 Honda VTX 1300 c
                slightly custom
                1979 XS 1100 SF
                in the works
                1979 XS 1100F, or
                1978 XS 1100E
                parts bike
                1980 XS 1100 SG
                just sitting partly torn down by PO
                playing roll of parts bike for now
                Hate to break it to the purists here but I cant go for the whole stock thing on this one.
                • tinman905
                  • Aug 2007
                  • 946
                  I have aslo heard from a few mechanics that you have to be careful using water because you can damage the valves using too much water.
                  BDF Special
                    • 7607
                    The water or seafoam into a HOT engine will work. Difference:
                    Water, Squirt a SMALL amount into each carb as you have the engine revving about 2,500RPM. Keep a fan blowing on the engine, and put a total of about 3 Oz. into each carb, about 30 seconds to put it all in.
                    When done, keep bike running for at least three more minutes to dry any water that may have gotten into the wrong place.
                    DO NOT do this more than once every 10K miles, as the water can burn the aluminum off the top of the pistons, and the head.
                    Seafoam, Again with the engine hot, squirt almost a full can of the spray into the four carbs, starting with the bike at about 1500RPM, and letting it kill the engine AFTER all four carbs have been hit. Shut the ignition and let the bike sit for ten minutes. Restart the bike and rev or ride it for a few minutes to "blow out" the now loose carbon.
                    To keep the carbon from building up, DO NOT USE PREMIUM GAS in a stock XS1100 engine. These engine are made to run on REGULAR GRADE gas, and mid grade or premium burns slower, and WILL cause a carbon build up in the engine.
                    • 11Rider
                      • Aug 2010
                      • 331
                      Thank you for all the advise.
                      • Woof
                        • Jul 2010
                        • 29
                        • Plano, TX
                        Try some RXP, it works great on my bike and all my cars.
                        • petejw
                          • 2269
                          • sydney australia
                          im doing a top end rebuild in a cpl of weeks
                          and thought id try this prior to the pull down,
                          and see what difference if any it does make.
                          ive got a 4 - 1 aquarium valve which ill attach to the
                          intake barbs with a restrictor connected to the
                          main line going into the water, as ray pointed out
                          ill fully warm up the engine prior and run it at a high idle
                          probably for around 10 min at a time, ill let u guys know
                          how it turns out, any other suggestions feel free to add.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                          • ManagerMike
                            • Mar 2010
                            • 445
                            • S.E. Michigan
                            Top engine cleaner. Its name is what it is made to do. Follow instructions on the can and make damn sure of the last instruction: change the oil.
                            However, if you intend to do a teardown for a recondition, why go through the trouble
                            '78 E "Stormbringer"
                              Now, that's one I've never heard. I was always told that water was about the safest method there was as long as you didn't squirt in too much and 'hydraulic' the motor.
                              I know that 'back in the day' when super premium gas disappeared and the guys with the big compression ratio motors were trying to figure out what to do (besides buying Avgas), full-time water injection setups became popular for a time. They weren't a cure-all (most ended up either running a octane booster, or lowered their compression ratio), but I don't recall any problems with a properly set up system...
