120,000 miles.
Back in Sept 2010 I wrote a thread on how my XS11 had an intermittent starting problem which exists to this day. The starter would spin the motor but provided no spark to the spark plugs. Today I found the problem; both pickup coils are cracked. And these are the original ones.
Does anyone have an idea where I can locate a coil assembly? Or can epoxying the cracks help?
And it seems straightforward to replace it. Because the 1980 model has those factory sheared bolts I do not want to disturb the base. The coils rest on a bearing and after removing the timing plate there are three screws that hold that bearing/pickup coil assembly to the base. Is it easy to remove the bearing/pickup coil assembly from the base or can the pickup coils alone be removed? Are there any locating pins or bosses so the timing is not disturbed?
Thanks for any help.
120,000 miles.
