To make a long story shorter; dragging rear brakes on my 80' Special. OK. Did the spooge hole thing (have done it before, thanks to posted pics and steps), still the pedal wants to stay down. Hmmm. I separated the actuating rod from the MC, AND,..pedal is VERY STIFF, definitely won't return with it's own spring. It must be forced back up into the neutral position. I checked CLYMERS, and it only gives lubrication instructions for the STANDARD (fitting under cap on the pedal mounting rod). Do I separate the pedal from the rod and then knock the rod back through the frame so I can lube it? What?...I don't like to hammer or force anything without some more knowledge. Thanks to all responders.
rear brake pedal very stiff return
Tags: None
Had the same thing on one that sat outside for 25years. Took the pedal off after disconnecting the push rod linkage and drove it out of the frame. Had lots of clean up on it and the frame as it was completely rusted tight. You'll want to make sure you don't mess up the splines where the pedal mounts. Also be sure to lube it up well and have the spring set correctly when re-assembling it.Richard -
How does that spring actually sit? Sometimes things come apart before you have time to remember how it is put together....
Theodore RooseveltComment
Thanks rpgoerlich, I guess parts wear out and get stiff with age...like me. I hope my problem won't be rust though. Heh. 69 April 5th.GenoComment
That shaft should just slide back and forth in the frame. Remove the pedal and tap it toward the frame. Be careful of the brake light switch, and the little spring that connects it to that shaft. You don't want to stretch it out. Otherwise, yes - remove it, clean and lube it, and put it back in.1980 XS850SG - Sold
-H. FordComment
Good tip. I'll be mindful of how it sits, so I'll be able to put'er back together. Thanks natemoen.GenoComment
I am actually asking the question too.......Nathan
Might be a good time to drill/tap a zerk fitting in there so this doesn't come back...Fast, Cheap, Reliable... Pick any two
Now that's another good idea; the middle part of the shaft is smaller diameter..good place for grease, and the fitting. thanks. P.S., Done yours?GenoComment
Been a while, but it hooks over top of the arm on the shaft just in front of the pivot for the push rod. The other end slips into a notch/cavity in the frame IIRC. As you load the spring push the shaft into the frame then release against the stop bolt.RichardComment
But it wouldn't take much to do...
