Final drive would be like doing the "750 FD Swap". Definitely not a direct bolt-on, but it can be made to work, with a noticable change in gearing. I believe the rotors will work, since I think all the XS rotors are the same, except for some having slots in them. The calipers, however, are a different story. The fronts will definitely not work, as they are from a Special, but I'm not sure about the rears.
Rotors from a 850SG are smaller 10 3/4" which would make them smaller than the XS1100 rotors.
BDF Special
Good to know! They sure LOOK the same.
Yes they do and I found out the hard way that they are different sizes
BDF Special
Are any parts off of a 1980 XS850SG compatible with my 1978 XS1100 such as final drive, brakes, rotors etc?
Thanks
Hi Figman,
direct swap:-
Front wheel, brake calipers, brake m/cs, handlebars & h/b switches, speedo, mirrors, front fender, rear light, signals, headlamp.
Won't fit:-
Brake rotors, tach, seat, gas tank, rear fender.
Will substitute:-
Rear drive unit to give lower ratio (less rpms at a given speed).
The left handlebar switch is different but can be made to work if you take it apart and do some mods on the wiring. I've done it once but I don't remember the exact procedure. It's not for the faint of heart or people than cannot solder...
