I have a Gas Tank leak
  • thefreeauction
    • Aug 2010
    • 22
    • Nebraska
    OK, a couple of weeks ago the ol Special started leakin gas.... Well, I'm lazy so didn't get to look at it until yesterday.. Well, after taking the gas tank off I found out it's leaking from the "low fuel sensor" area under the gas tank. More specifically around the little rubber grommet around the electrical wireing... So does anyone have a part number for this right off hand? Or at least what the "official" name for this is? Or where to get one?
    I assume my best bet is to just replace the whole fuel sensor piece and call it good?
    Thanks for any suggestions.
    Dan
    1980 Yamaha XS1100 Eleven Special
    Is it coming through the area that the wire connections come through plate, or around the plate where it blots to the tank?
    • thefreeauction
      • Aug 2010
      • 22
      • Nebraska
      It's leaking through where the wire comes through the plate. I didn't unbolt anyting else as I still had gas in the tank.
        Could always try brazing the crack closed. Or you could just replace the sending unit. either works.
          That is a "sending unit", and is no longer available, as far as I remember. If you don't want to worry about the light, you can make a steel plate to replace the sending unit. If you run the tank down most of the way, you should not even have to totally drain it.
          Re-use the rubber gasket and paint the cover on the outside so it will not rust.
            Cant get new ones but you can still get used ones.
            • thefreeauction
              • Aug 2010
              • 22
              • Nebraska
              Hey thanks for the info guys.
              I really like the assurance of having the low fuel light working, so I'll probably try my luck with a used unit. (now that I know what it's called )
              Off to eBay I go!
              Thanks again.
              • SFerinTEXAS
                • Jun 2006
                • 877
                Might try some kinda of epoxy, There is one for gas tanks.
                79SF
                XJ11
                78E
                  Originally posted by thefreeauction
                  OK, a couple of weeks ago the ol Special started leakin gas.... Well, I'm lazy so didn't get to look at it until yesterday.. Well, after taking the gas tank off I found out it's leaking from the "low fuel sensor" area under the gas tank. More specifically around the little rubber grommet around the electrical wireing... So does anyone have a part number for this right off hand? Or at least what the "official" name for this is? Or where to get one? - - - - Dan
                  Hi Dan,
                  "low fuel sensor" is good enough that anyone who has one knows what you mean.
                  You can't buy new ones. Look in the list's "XS11 parts for sale" forum. The most likely source there is Andreas Weiss.
                  Or swap to a Standard tank, it's at least a gallon bigger.
