Another Jetting Question
  • shadowman
    • Dec 2010
    • 30
    • Newcastle Ontario
    Okay guys, I'm glad to have that straightened out for me. I hope to get some time this afternoon to dig into the carbs.
    Thanks
    1981 Special- currently under construction
    • shadowman
      • Dec 2010
      • 30
      • Newcastle Ontario
      I took the carbs apart this afternoon and cleaned everything again. The emulsion tubes looked good, but my floats were quite low. (with the carbs upside down) I set them all to exactly 23mm. It started great on full choke. I let it run for about a minute, and put it to half choke. After about 3 or 4 minutes it started to rev right up. I turned the choke off and it settled down to a nice smooth idle. I revved it up and everything seemed good. I went through the gears, on the centre stand, and all seems good.
      I'll have to wait a bit before I can take it out for a proper test, but it's at least at a way better starting point. Now I have to get a carb synchronizer.
      Thanks again guys.
        Congrats!!! And for future purpose the 23 is +/- .5 mm.
        As to synching, I use a mity-vac for the vacuum gage hooked to a plenum made out of PVC pipe and a single tube. I go carb to carb and read the vacuum, adjust with it hooked to one to the midpoint of the two and measure again. Takes longer to get it set right than a four gage set. But pretty dang accurate really. And cheap, which is my middle name...sooooo.
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          But I paid about $50 for my 4 gauge set and it's sure nice to get it warmed up, hook up the 4 gauges and have everything set generally in less than a minute (once they are hooked up). Well worth the money in my opinion, but YMMV.
          I figure my time is worth enough to make the time savings pay off the higher cost pretty quick.
          • petejw
            • 2269
            • sydney australia
            great stuff,
            glad you got it all sorted.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
