Cylinder Honing
  • Cylinder Honing
    I am going to have to buy a ball hone so I can rering this beast. Anyone have any suggestions for appropriate hone grit to use? Or any advice for doing the actual honing itself?
    Hey Nate,
    I did a search and found the manufacturer of the ball hones site, took a while to find it, but I found this page:
    http://www.brushresearch.com/literature.php?type=2
    And at the bottom is a PDF file/book they have to help determine what grit and such you would want to use. I didn't D/L it or look at it, but looks like they have lots of info there!
      I will have to give that a read, thanks TC.
        hi nate,
        im in the process of doing the same thing,
        u can also use a honing stone,
        the main thing is getting a good cross hatch,
        keeping the hone moving up and down,
        and getting rid of all the glaze in the cylinders.
        let us know how u go.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
          http://basisnz.co.nz/product.pasp?ca...productid=2698
          This is what I use. Stones are replaceable with your grit of choice, and the flat stones will show up any pitting or imperfections in the bore better than a ball hone will.
            thats the one im after Brian,
            what grit have u been using with it?
            is the 280 to course?
            the only thing to be careful about using these
            is not to go to far past the bottom of the cylinders
            other wise the thing expands and can go to pieces.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              I have straight stone hones but have never been able to get a cross hatch with them. Ball hones are pretty fool proof.
              What are the xs cylinder sleeves made of?
                lol
                ive never used the ball type before,
                with the stones u need to consistently keep
                moving them up and down.
                the sleeves are steel.
                u putting new standard rings in nate?
                ive bought the .25 over size rings from ebay that
                ill file down the end gaps.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                  .25 over is what I got. Last summer I was buring oil at about 1-1.5 quart every 50-100 miles so I pulled the jugs and gave a quick hone with my straight stones (i mostly only ever use them for a rough first hone so I dont care about cross hatch, cause I can't ever get.it anyways) and put her back together. Didn't really solve the oil problem and I actually lost.some compression from that. So now its a more thorough and proper job this time.
                    me too,
                    been spending more on oil than fuel atm.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      It's almost like driving a special, they have to stop for gas every 100 or so miles, and I had to stop for oil......oil is more expensive though
                        i ride a special/sport.... :-)
                        i was running 70n weight oil for
                        old worn out engines, that was better,
                        but still worked out expensive as it was
                        more than twice the price of the cheaper stuff.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • #13
                          Yeah I went to 80/90 for awhile just to see what would happen and it was still burning, just a little slower.
                          • #14
                            Anyone have any thoughts on a 73mm 240 grit silicon carbide hone?
                            • #15
                              Composition
                              I suppose we would need to know the composition of the steel in our cylinders, if we follow the flex hone chart.
                              78 XS1100E Standard
                              Coca Cola Red
                              Hooker Headers
                              http://i408.photobucket.com/albums/p...m/DSC00580.jpg
                              1979 XS1100 Special
                              http://i408.photobucket.com/albums/p...m/DSC00612.jpg
                              1980 XS Standard
                              http://i408.photobucket.com/albums/p...m/DSC01137.jpg
                              2006 Roadstar Warrior
                              http://i408.photobucket.com/albums/p...um/warrior.jpg
