I am going to have to buy a ball hone so I can rering this beast. Anyone have any suggestions for appropriate hone grit to use? Or any advice for doing the actual honing itself?
Cylinder Honing
Cylinder Honing
Theodore RooseveltTags: None -
Hey Nate,
I did a search and found the manufacturer of the ball hones site, took a while to find it, but I found this page:
And at the bottom is a PDF file/book they have to help determine what grit and such you would want to use. I didn't D/L it or look at it, but looks like they have lots of info there!
T.C.T. C. Gresham
How nature points out the folly of men! -
I will have to give that a read, thanks TC.Nathan
Theodore RooseveltComment
hi nate,
im in the process of doing the same thing,
u can also use a honing stone,
the main thing is getting a good cross hatch,
keeping the hone moving up and down,
and getting rid of all the glaze in the cylinders.
let us know how u go.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
BASIS is the secure online shop where car enthusiasts and restorers can buy classic car and vintage car parts. Holden, Ford, Austin, Jaguar, Daimler, Triumph, Jowett, MG, Mini, Morris, Vauxhall, Rover, Landrover, BMC and more. Window seals, bearings, engine parts. Classic car clubs welcome. Open Monday to Saturday.
This is what I use. Stones are replaceable with your grit of choice, and the flat stones will show up any pitting or imperfections in the bore better than a ball hone will.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
thats the one im after Brian,
what grit have u been using with it?
is the 280 to course?
the only thing to be careful about using these
is not to go to far past the bottom of the cylinders
other wise the thing expands and can go to pieces.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
I have straight stone hones but have never been able to get a cross hatch with them. Ball hones are pretty fool proof.
What are the xs cylinder sleeves made of?Nathan
lol
ive never used the ball type before,
with the stones u need to consistently keep
moving them up and down.
the sleeves are steel.
u putting new standard rings in nate?
ive bought the .25 over size rings from ebay that
ill file down the end gaps.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
.25 over is what I got. Last summer I was buring oil at about 1-1.5 quart every 50-100 miles so I pulled the jugs and gave a quick hone with my straight stones (i mostly only ever use them for a rough first hone so I dont care about cross hatch, cause I can't ever get.it anyways) and put her back together. Didn't really solve the oil problem and I actually lost.some compression from that. So now its a more thorough and proper job this time.Nathan
me too,
been spending more on oil than fuel atm.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
It's almost like driving a special, they have to stop for gas every 100 or so miles, and I had to stop for oil......oil is more expensive thoughNathan
i ride a special/sport.... :-)
i was running 70n weight oil for
old worn out engines, that was better,
but still worked out expensive as it was
more than twice the price of the cheaper stuff.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Yeah I went to 80/90 for awhile just to see what would happen and it was still burning, just a little slower.Nathan
Anyone have any thoughts on a 73mm 240 grit silicon carbide hone?Nathan
Composition
I suppose we would need to know the composition of the steel in our cylinders, if we follow the flex hone chart.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
