1978 XS11, which carbs will work?
  • 1978 XS11, which carbs will work?
    I am in the process of getting this bike on the road, but one of the carbs,(far left with choke lever), was letting a lot of gas out through the air cleaner.
    Figured it was a sticking float.
    When I removed it, I found that one of the towers that hold the pin, that holds the float was broken.
    Anyway, I am in need of at least the one carb, but would consider a whole set.
    Can anyone tell me which years will work on my bike?
    And as long as I am asking questions, does anyone have some they want to part with?
    I really only need the main carb body because all the other parts ar fine.
    Thanks in advance for any help you can offer.
    1979 XS1100
    1974 CB750
    1985 V65 Sabre
    1988 KLR650
    2001 CR250
    There are several good (relatively speaking) permanent fixes that have been written up and posted here to deal with the somewhat common broken post.
    Otherwise you you would need a 78 or 79 far left carb. If its any other carb it will not work cause it will not have the right holes tapped for the choke.
      #1 Carb
      Does it look like this one?
      78 XS1100E Standard
      Coca Cola Red
      Hooker Headers
      http://i408.photobucket.com/albums/p...m/DSC00580.jpg
      1979 XS1100 Special
      http://i408.photobucket.com/albums/p...m/DSC00612.jpg
      1980 XS Standard
      http://i408.photobucket.com/albums/p...m/DSC01137.jpg
      2006 Roadstar Warrior
      http://i408.photobucket.com/albums/p...um/warrior.jpg
        If you change the whole rack any of the years will fit. The XJ carbs IIRC the emultion (choke) is different but workable.
        Ty
        78 XS1100E - Now in Minnesota
        80 XS1100LG - The Punisher
        82 XJ1100 - Daughter's Bike
          Looks pretty close, except for where the float bowl attachs.
          The on in the picture looks different.
          Do you have a picture of it looking down on the bowl area?
          1979 XS1100
          1974 CB750
          1985 V65 Sabre
          1988 KLR650
          2001 CR250
            78-79
            This is a 78-79 carb. I'll get you a pic from the top.
            78 XS1100E Standard
            Coca Cola Red
            Hooker Headers
            1979 XS1100 Special
            1980 XS Standard
              here is a picture of mine from the top
              http://i1112.photobucket.com/albums/...sscycle255.jpg
              1979 XS1100
              1974 CB750
              1985 V65 Sabre
              1988 KLR650
              2001 CR250
                top
                Here is the top of one of my spares.
                Looks like your posts have be modified??
                78 XS1100E Standard
                Coca Cola Red
                Hooker Headers
                1979 XS1100 Special
                1980 XS Standard
                  looks like it should work. PM'd ya.
                  1979 XS1100
                  1974 CB750
                  1985 V65 Sabre
                  1988 KLR650
                  2001 CR250
                    Looks like you got a carb body that will replace yours.
                    You do want the same style for replacing but as stated, any of the XS models will run your engine fine if you replace the entire set. The XJ models use a different setup for the choke activation (cable linkage), otherwise they direct swap as well.
