And that's exactly the one I was thinkin of. Don't have room for big beast just yet.
Serious Carb problem
2005 Honda VTX 1300 c
slightly custom
1979 XS 1100 SF
in the works
1979 XS 1100F, or
1978 XS 1100E
parts bike
1980 XS 1100 SG
just sitting partly torn down by PO
playing roll of parts bike for now
Hate to break it to the purists here but I cant go for the whole stock thing on this one. -
Well fed if you cab convince SWMBO to let you spend that much, don't turn her down! Even if you dont actually spend it all stockpile the cash
Theodore RooseveltComment
Idle screw press ??
Fireplug, don't feel bad. There's a bunch of real good mechanics and shade tree ones too, that have been in this predicament. While doing my carbs I managed to break 3 out of the 4 tips in the carb throat. After trying all the options adviced to by the friends at this forum I could not get them out.
Finally, I gave up and called my friend who I knew would figure out a way.
Sure enough, here's what he came up with.
He found small drill bits the same measurement as the hole where the needle was in. I believe around .024in. He cut a bolt to size and drilled a hole in the head to fit the bit in, rounded the hex out of the bolt somewhat and matched an acorn nut to fit.
He cut 2 sizes in lenght of the bits and started with the short one to press it out. When it topped out he changed to the longer one and VOILA !!79 XS1100F.
TC's fuse box.
SOFA filter.
Venture cam chain adjuster.
Tkat fork brace.
Progressive fork springs.Comment
That's a good way to do it. Basically an internal press!Nathan
going to have to try this...only thing that might work_____________________________________________ 1979 XS 1100 Special "The judge" mods- K&N air pods, 4-1 mac, 147.5 pilots, 57.5 mains, LED turn signal, cafe bars, HEL translucent yellow stainless steel brake line, dyna coil (dc2-1), raptor 660 mc, r6 controls..(sold)
1980 gs1000g "stock"
2008 jmstar 150cc Chinese scooter ( wife's bike)Comment
Hey Tropic, I'm loving that idea thank you. When I figure out if n when I'm moving ill definitely give that a shot first. Thanks again2005 Honda VTX 1300 c
slightly custom
1979 XS 1100 SF
in the works
1979 XS 1100F, or
1978 XS 1100E
parts bike
1980 XS 1100 SG
Hate to break it to the purists here but I cant go for the whole stock thing on this one.Comment
Now that's an elegant solution! Much better looking than the push pin trick and its variations.Ken TalbotComment
I had tried everything!
I'm telling you I had given up already. I had tried heat, cold, push pin, L shaped o ring puller, etc. Basically everything advised by the forum and other thoughts I had. Nothing had worked. When my friend saw the problem and made the tool, I was amazed at the simplicity and the ease which the pins came out.
Hope all who try it get the same results I did.79 XS1100F.
TC's fuse box.
SOFA filter.
Tkat fork brace.
I'm telling you I had given up already. I had tried heat, cold, push pin, L shaped o ring puller, etc. Basically everything advised by the forum and other thoughts I had. Nothing had worked. When my friend saw the problem and made the tool, I was amazed at its simplicity and the ease which the pins came out.
TC's fuse box.
SOFA filter.
Tkat fork brace.
Very Slick!! One of those things where once you see it you go "Now why didn't I think of that!!" Those are the ones that impress me most.Life is what happens while your planning everything else!
78 XS750Comment
