Serious Carb problem
  • Fireplug
    • Feb 2011
    • 23
    • Phoenix, AR
    My issue is that a PO has broken the tips of three of the mixture screws off in the Carb bodies. Hoping against hope I have sprayed them with nearly everything I have in the garage and now I'm trying Marvel Mystery Oil. I'm pretty sure I know whatvi SHOULD do ( throw them in the can ) but I'm not ready to give in to that. Thinkin bout trying the ultrasonic cleaner but so far I'm not impressed with how its cleaning. ANY thoughts ideas or help would be greatly appreciated. BTW is anyone else on here. From the Phoenix area?
    2005 Honda VTX 1300 c
    slightly custom
    1979 XS 1100 SF
    in the works
    1979 XS 1100F, or
    1978 XS 1100E
    parts bike
    1980 XS 1100 SG
    just sitting partly torn down by PO
    playing roll of parts bike for now
    Hate to break it to the purists here but I cant go for the whole stock thing on this one.
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    Somewhere on here there was a post by someone who made a tool to press those out i think.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
      Do a search on mixture screw tip and broken or stuck. LOTS of options for how to get them out. One of them may work for you.
      The most popular way that has seemed to work recently for folks is to put the carbs in the freezer for a bit and try to push it out. The brass the screw is made out of shrinks more than the aluminum and it can loosen them enough to get them out.
        Yeah plenty of options on here, thankfully I have never had to deal with this!
        • Giggity
          • Mar 2009
          • 113
          • Longmont, CO
          I had the same problem - 3 broken tips - and tried every suggestion I found on here. Nothing worked and I finally had to drill them out. I hope you have better luck!
          1979 XS1100 Standard
          Putting it together........
            Hi Fireplug,
            if all else fails, drill the bastards out.
            A hand-held drill will not be precise enough to do the job.
            You'll need to use a drill press so you can centre the drill bit and you'll need to block the carb body up dead square on the drill press base plate.
            A 1mm drill bit is just about right but we used a 1/16" because that's the skinniest drill bit that the chuck on our drill press will grip.
            If you use the 1/16" drill bit just don't thread the new needle out as far; worked OK for us.
            • foreda
              • 949
              • Southwest Louisiana
              Carbs
              If all else fails and they are 78-79carbs, I think I have some spare bodies I could sell you. You would need to completely disassemble to replace.
              78 XS1100E Standard
              Coca Cola Red
              Hooker Headers
              http://i408.photobucket.com/albums/p...m/DSC00580.jpg
              1979 XS1100 Special
              http://i408.photobucket.com/albums/p...m/DSC00612.jpg
              1980 XS Standard
              http://i408.photobucket.com/albums/p...m/DSC01137.jpg
              2006 Roadstar Warrior
              http://i408.photobucket.com/albums/p...um/warrior.jpg
              • DELL82
                • May 2006
                • 260
                • Houston, Texas
                The idea is to get the stuck pin frozen and the aluminum body hot. this will open the clearance around the pin and it should press out easily.
                To do this sprayCO2 around the pin and pin or place in freezer until carbs are as cold as the freezer, several hours. Using a small hose or tube over the pin, heat the carb body in the area to swell the aluminum up and open the clearance.
                Idea is to not heat the pin while heating the carb body.
                Dell82
                Dell82
                Houston, TX
                82' XJ1100J Maxim "LASERMAX"
                SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
                SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
                SOLD 82' CB450SC Nighthawk, parts bike SOLD
                • Fireplug
                  • Feb 2011
                  • 23
                  • Phoenix, AR
                  Hmmm. I've been thinking bout the freezer thing for a while. But now I'm thinkin bout the drill press if for no other reason than I get to buy a new tool. That you everyone for all the ideas. Keep em coming n ill keep you posted
                  slightly custom
                  1979 XS 1100 SF
                  in the works
                  1979 XS 1100F, or
                  1978 XS 1100E
                  parts bike
                  1980 XS 1100 SG
                    Drill press I say should be last resort, if by chance you change the holes even a little it could make it VERY hard to tune the carbs!
                    • lee_dutcher
                      • Apr 2009
                      • 822
                      • mason city iowa
                      im in the same boat fellow xsive....as i speak/type the carbs are in the freezer lets hot this works
                      1980 gs1000g "stock"
                      2008 jmstar 150cc Chinese scooter ( wife's bike)
                        Just try more than once if it doesn't work before going to the extreme.
                        • Fireplug
                          • Feb 2011
                          • 23
                          • Phoenix, AR
                          oh i agree drilling is absolutely the last resort. think ill wash them real good tomorrow and freeze them
                          slightly custom
                          1979 XS 1100 SF
                          in the works
                          1979 XS 1100F, or
                          1978 XS 1100E
                          parts bike
                          1980 XS 1100 SG
                            Curious to hear how it works for both of you guys.
                              Hi Fireplug,
                              like I said, "if all else fails". But WTF, like anybody else, you need a drill press anyway!
                              While a posh $1,000 floor model would really enhance a person's workshop, a Harbor Freight bench drill on special at $69.99 is all you really need.
