need help!!!where to find oil filter screw
  • darookie
    • Sep 2003
    • 11
    • Boston
    my oil filter screw is stripped to death..where can i buy another one at..
  • Bikeboy
    • Jan 2003
    • 127
    • Memphis.Tn
    oil filter screw
    hi darookie. chris here, i got mine from the YAMAHA dealer last year. but i have a 79f XS11, not sure if it's the same size. cost about $9.00.
    Chris 79 XS11F With mods....!!!!!! 2005 FXST Harley Softail
    • buggrin
      • Aug 2002
      • 88
      • South Carolina
      filter screw
      Remember seeing them while browsing some of the online dealers listed in the info section. Can't remember which one -- maybe Zanotti
      Bob
      • Jeff
        • Apr 2003
        • 263
        • Pocatello, Idaho
        For the XS... the oil filter bolt is still readily available since it still fits a few of the more modern bikes.
        Any Yamaha dealer should have one in stock. The original stock part is a bit expensive but the aftermarket replacements are only about $8 or so.
        Online.... you can order one from Parts-n-More, Power Sports Pro (PartsFish) or Dennis Kirk.
        If you are having difficulty getting the bolt out.... since they are quite oftentimes grossly overtorqued..... you can tack weld a socket over what is left of the bolt head and wrench it out that way.
        1978 XS1100E "Flashback"
        "If at first you don't succeed.... Get a bigger hammer."
        • jawnski
          • 14
          • Fresno, California
          Ha. I went through the same thing. The dealer wanted $68 or some crap for the bolt. I did see it on an online catalog for about $8 somewhere like the others.
          What I did is used an bolt extractor (like an opposite e-z out. I got a set at Sears for $20). I wleded a big deep nut on the bolt and it's way better than stock and will NEVER get stripped again.
          Good luck
          • jawnski
            • 14
            BINGO
            Found your Part OIL FILTER BOLT
            Fits XS1100LG/LH (80-81) $6.00US ea.
            พบประสบการณ์ใหม่ของการเล่นเกมสล็อตกับเว็บที่รวมเกม slot แตก ง่าย จ่าย จริง พร้อมระบบอัตโนมัติ เล่นสนุก จ่ายเต็ม ไม่มีโกง 2025
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              I got one from JC Whitney. Works just fine.
              Pat Kelly
              <p-lkelly@sbcglobal.net>
              1978 XS1100E (The Force)
              1980 XS1100LG (The Dark Side)
              1999 Suburban (The Ship)
              1994 Dodge Spirit (Son #1)
              1968 F100 (Valentine)
              • darookie
                • Sep 2003
                • 11
                • Boston
                will that bolt fit on my 1982 xj1100...i have an xj not xs..
                  Yes, the same bolt will work for the XJ and the XS, that part of the engine is the same!!!
