my oil filter screw is stripped to death..where can i buy another one at..
need help!!!where to find oil filter screw
For the XS... the oil filter bolt is still readily available since it still fits a few of the more modern bikes.
Any Yamaha dealer should have one in stock. The original stock part is a bit expensive but the aftermarket replacements are only about $8 or so.
Online.... you can order one from Parts-n-More, Power Sports Pro (PartsFish) or Dennis Kirk.
If you are having difficulty getting the bolt out.... since they are quite oftentimes grossly overtorqued..... you can tack weld a socket over what is left of the bolt head and wrench it out that way.1978 XS1100E "Flashback"
"If at first you don't succeed.... Get a bigger hammer."
Ha. I went through the same thing. The dealer wanted $68 or some crap for the bolt. I did see it on an online catalog for about $8 somewhere like the others.
What I did is used an bolt extractor (like an opposite e-z out. I got a set at Sears for $20). I wleded a big deep nut on the bolt and it's way better than stock and will NEVER get stripped again.
Good luck
BINGO
Found your Part OIL FILTER BOLT
Fits XS1100LG/LH (80-81) $6.00US ea.
http://www.partsnmoreonline.com/PNMS...e%20parts.html
I got one from JC Whitney. Works just fine.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
