Used 2nd and 5th gears wanted
  • DELL82
    • 260
    • Houston, Texas
    I am trying to machine the 2nd gear fix using a Super spacer with a digital mill.
    I need some used, unserviceable, gears to practice on. I have tried one set from Stan H. however my centering was off and the gears are not usable. I found the right tooling to use and have set the super spacer 1.5 Degrees tilt to get the angle right. Angle on my first attempt was good, interlocking was good but the dogs were off.
    Any takers?
    If the machining comes out I can put the gears into my XJ and machine my worn gears to return to you, no charge. Should this system work I can then machine others for a minimal fee plus shipping.
    Will be much cheaper then the $200+ for NEW gears and be just as strong with the taper fit.
    Thanks
    Dell82
    Dell82
    Houston, TX
    82' XJ1100J Maxim "LASERMAX"
    SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
    SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
    SOLD 82' CB450SC Nighthawk, parts bike SOLD
  • brcree
    • Mar 2010
    • 388
    • S.C.
    gears
    Hay Dell...I have a complete set I just removed from my 81 1100 special. Some of the gears have broken teeth, if you can use them send me your add.!
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
      I have the spare gears from Special Ed's bike. They are in bad shape, but should be serviceable. Send me a PM if you want the set, and you will have them to play with.
