Hey Pat,
Thanks for taking time from your busy trucking schedule!
The backwards rotation only affects the cooling, and so I just have to make sure to be able to get a reversible fan blade for it. The other electronic tachs that work off of the ignition coil trigger are available from MikesXS for a modest price, but they are not the same size as OEM!
This is partly why I'm hoping to be able to keep the OEM tach/trigger system!
Tachometer - Electronic Electronic Tachometer (operates from Ignition pulses) 0-12,000 RPM
1.9 Dia. (48mm.), Black Face Tach functions only with single dual
output type ignition coils - (80-84 factory Tci). Part #03-0675$69.00 USD Ea
One of our PAIR of output coils are DUAL OUTPUT, and would only need to be connected to one of them, same wasted spark design, same spark count.
This is partly why I'm hoping to be able to keep the OEM tach/trigger system!T.C.
Left a nice 10" sized puddle on the floor!
I then drained the oil, pulled the filter, and then removed the SOFA. This was the modified O-ringed one that I had cut the groove into. HOWEVER, the groove was square...I had quickly changed to round ones thanks to Toolmaker Tim suggesting I use a roundnose milling bit. But this was an early square cut groove and I had made it a bit deeper than it should have been, so the O-ring had flattened too much because of too much room in the square groove and being too deep. I put the SOFA on my lathe and turned it down to the 0.08" depth that I had been using for my other productions. Cleaned it all up, put a new O-ring/sealant, thread lock and put it back on. It's still curing, will test it tomorrow, will be in the upper 50's then!
As I stated earlier, the threading of the rotor bolt is CLOCKWISE and the CCW rotation helps to apply a tightening spin, so even if the bolt did work loose, the CCW rotation would seem to help keep it snug!?
