hey everyone. gathering items to try rust removal from xs exhaust pipes. Don't want to screw this up, which I have a tendency to do. two quick questions.
1. When taking out of electlolysis solution, what do i scrub rust with ti loosen but not mark chrome? they say to use wire brush, but wouldn't that sctatch chrome? Also, dip,scrub,dip,scrub. correct process?
2. have heard from most who have done this, when taken out of solution, usually has some black residue and will rust over quickly if not dried fast. was told to use alchohal right away and then polish? also, what di I do about inside of pipes? should I use compressor air to dry quickly? Don't want inside to rust.
thanks for any info available. Dave
P.S. Will be doing test run on leftover honda exhaust pipe before starting good one. seems probably to be a good idea to get feel for process,hooking e/thing up correctly,etc.
