What is the brake pad of choice these days? Long life is not desired, I just want good brakes.
brake pads, what brand?
1982 XJ650RJ Seca
2001 Yamaha XT225
2002 Suzuki DR650
2008 Suzuki DL650 VStrom
AMA charter life memberTags: None -
i have ebc brake pads on my xs.. paid 32 bux shipped_____________________________________________ 1979 XS 1100 Special "The judge" mods- K&N air pods, 4-1 mac, 147.5 pilots, 57.5 mains, LED turn signal, cafe bars, HEL translucent yellow stainless steel brake line, dyna coil (dc2-1), raptor 660 mc, r6 controls..(sold)
1980 gs1000g "stock"
2008 jmstar 150cc Chinese scooter ( wife's bike) -
There's basically two choices among the various brands; organic or metallic (aka 'sintered'). Organic will have generally slightly shorter life, are easier on the rotors in terms of wear, work better cold but will fade under heavy use faster than metallic. Organic is less likely to give you brake squeal also.
Metallic is better under heavy braking once warmed up, can be noisier, and can wear the rotors faster. It generally costs more too.
Truthfully, there's not a huge difference between them and your riding style will have a lot to do with how happy you are with a given type. If you like to do a lot of high-speed corner-carving, metallic will probably be the better choice. I think Vesrah is the only major maker still listing metallic pads for these bikes (EBC did also at one time, but all I can find now are kevlar organic), but you may find some in other brands if you look around.
You have a 'standard', so there's a few more choices. I'll also mention that Yamaha fitted 'front' and 'rear' pads originally to the standards, but these are long-discontinued and now the pads are the same front/rear.Last edited by crazy steve; 01-30-2011, 01:15 PM.Fast, Cheap, Reliable... Pick any two
I ran EBC for years. Decided to try Vesrah cause they were a bit cheaper. Developed a brake squeal that would make you go blind. Nothing I did would make it go away for long. Went back to EBC and everything is good.When a 10 isn't enough, get a 11. 80g HardbaggerComment
Thanks for the info everybody, this is what I needed.
Tom1978 XS1100E
1982 XJ650RJ Seca
2001 Yamaha XT225
2002 Suzuki DR650
AMA charter life memberComment
These ceramic pads are pretty good.
ON-LINE CATALOG GOLDfren is a brand of brake and brake components manufactured in the Czech Republic. We manufacture sintered brake pads, brake linings, clutches and clutch segments, brake hoses and hoses, brake discs, brake callipers and brake motors not only for motorcycles but also other braking and braking componentsComment
