lookin for a good air, water evaparator for my compressor to paint a few tanks, im not looking for the best on market, but needs to be good enough to paint a tank or 2 without water spots a foulin up my paint job. any home made remiedy will be fine to. i know you can get the little attachment filters to put inline on the gun and so,forth but i dont trust them, had one to leak water out on a primer job on my truck when i primed it. any way if any ideas are out there post them, thanks
hey everyone
Tags: None
Harbor Freight has a filter regulator combo for something like 30 buck. Not the best but does the job for cheap.Nathan
Theodore Roosevelt -
evaporater
thanks nate i'll check them out now. still open to other thoughts also.79 xs 1100 spec & 80 xs 1100 gComment
The HF unit isn't that good (I've got one), but if you want better be prepared to pay for it. Try http://www.eastwood.com for a better quality (and higher priced) separator. If you're using a HVLP spray gun, it isn't as big a deal IMO.
I use the smaller 'detail' gun from this set: http://www.harborfreight.com/profess...kit-94572.html for painting bike parts and other smaller bits. The volume/pressure this gun needs is low enough that water doesn't seem to be an issue.Fast, Cheap, Reliable... Pick any two
