rust and chrome not good mix
  • dschmitta
    • Jul 2010
    • 174
    • Altoona,PA
    Hey everyone,
    own 1080 11g. put away for winter. I did it as simple as I could(which means the lazy way) by just treating fuel, mixing well, and running to make sure mixed into carb bowls. Just figured I'd go out once a weak and start and run for charge and warm engine up. Well, forgot to plug exhaust in between warmups and pipes got loaded with mice nests. Didn't notice until smelled something funny and saw smoke pouring from pipes. Anyway, I decided to take off pipes and clean them out.(Yes, I plugged front cylinder openings well), but when I got pipes off, on the underneath, all four are rusting. Didn't notice while riding, even though I cleaned and polished them because the tops are nice and shiny! I even worked the polish behind pipes but didn't feel any resistance to lead me in that direction. How do I get the rust off of the pipes with minimal damage to the good chrome? Any ideas greatly appreciated. Thanks. Dave
    1980 xs1100g
  • CatatonicBug
    • 6117
    • Clinton, UT
    You could try electrolysis, like in this thread. Looks like it did a REALLY good job on those pipes!
    • XSive Okie
      • Jun 2010
      • 281
      • Enid, OK
      I believe #0000 steel wool works pretty good.
      Richard
      '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
      '02 Honda VTX1800C
      • ThrottleJunky
        • Jan 2011
        • 183
        • PNW
        This guy has some pretty good before and after pictures to back up his method:
        1980 XS1100G. Work in progress.
        1980 XS1100G. 2nd work in progress.
        • figman
          • Mar 2009
          • 103
          • Asheboro, NC
          SOS pads may aid in removal of the rust on the underside of the pipes..
          current bikes:
          1983 GS 1100E
          2009 Kaw Vulcan 1700 Classic
          past bikes:
          1978 XS 1100
          1994 FZR 600
          1984 V65 Sabre
          1973 CB 750
          1974 CB 750
          1979 KZ 750 twin
          1977 CB 550
          1983 XJ 750 Seca
          1981 900 super sport
          too many others to list
          • DAVINCI
            • Jan 2011
            • 1048
            • Cedar Mountain, NC
            Scrub with aluminum foil and coca-cola. Phosphoric acid in the cola dissolves rust
            • thecamelman79
              • Dec 2010
              • 81
              • Havelock, nc
              Depends alot on how bad they are and what kind time you wanna put it to it. Belive it or not I have had great luck with http://www.acehardwareoutlet.com/pro...rce=GoogleBase turtle wax chrome polish and rust remover and a tooth brush for light to med rust. Which from you description sound like what you got.
              But as C-Bug said, I have found electrolisiys to be the difinative rust remover with out damaging your chrome.
              ~Camel
                Yeah, I'm a polish-and-toothbrush guy too (although I'll use a SS brush on heavy rust) as that seems to do the least damage to the plating that remains.
                One thing about rust though; once it's shown up, it'll be back faster so regular polishing/waxing needs to be done more often...
                • dschmitta
                  • Jul 2010
                  • 174
                  • Altoona,PA
                  ~Camel
                  I know I found a site to show how to set up the electrolysis method somewhere on this site, do you know where by chance? There used to be a link, or maybe you could explain it. I really would appreciate it. Pipes definately are in need and I have at least a month or two until riding time in Pa. thanks.Dave
                  1980 xs1100g
                    That or a good ceramic coating or powdercoating. I've not heard of anybody having good luck with paint under those conditions.
                    • Wet Rock
                      • Dec 2005
                      • 51
                      Camelmans thread
                      You can try the NAKED BOY thread....Page 5 when youre not logged in
                      • Poprock
                        • Apr 2005
                        • 594
                        • Oregon Coast
                        0000 steel wool will scratch chrome on exhaust pipes. Only do that if you plan to go for Jet Hot coating soon. That stuff is good, BTW. Looks good, lasts a very long time, pipes run cooler.
