What are these prongs for?
  • James England
    • 3039
    • North of England
    This may sounds a bit nerdy but I've taken several XS1100's apart and always wondered what the two prongs are which are found on the metal support bracket for the rear mudguard. I took my seat off tonight and saw them again.... what are they for? You can see them at the middle of the bracket in the photo, facing left.........
    Anybody out there know?
    On Tsunami and Purple Reign, they hold a spare electrical connector of some sort.
    Never have gone looking to see what the plug is for, but probably has something to do with more lights at the rear end.
    • James England
      • 3039
      • North of England
      Aha! So that's what they're for... It'll be something on the wiring loom that we don't have here in the UK........ Thanks!
        Turn, brake, and running lights. I thought they were for the touring package but it looks like you have it Ken and they are not used.
        • thecamelman79
          • Dec 2010
          • 81
          • Havelock, nc
          Its the reserve lighting unit.
          for touring bags.
          should be 6 wires in the big bundle and two in the small one.
          Edit: how did I not see you already answered that?
            All good guesses.........Ken is the closest! That is a plug in for trailer lights. Ironic cause the owners manual warns against trailer pulling, yet has a factory installed plug-in which is all still intact on mine also. Just know that as I was informed that when I bought my V
            enturer new. The other extruding tab is for the cable to hold suspension up to remove the axle shaft by the mufflers.......not needed on the 81 Specials or Standards, although mine came with the cable stored in the latch box on the inside of the left cover..........go figure having the short upswept exhaust on all three of the 81 models.
              BTW, the right side swing-arm has a small loop weled on to attach the cable hook holding swing arm up. The looped end of cable hooks on that extruding piece. Hope that helps the curiosity part......
