Hi- new owner of XS1100.
    Hi Throttle Jockey,
    I see you are our NEWEST member and likely to stay so as wecan not accept any new members until th "Meteor shower" of spammers passes. At this rate you could reach Guru staus as the newest member
      I'll second the 'take it all apart and clean it' on the brakes. If the bike was stored in a reasonably dry place, just doing this will usually solve any brake issues. Like 'bug said, make sure you pull and clean behind the seals as that's where many problems are. Most cases, you won't even need any parts. If you run into rusty/pitted caliper pistons, those probably should be replaced and look very closely at the seals. Make sure to clean the imfamous 'spooge hole' in both M/C too.
      Make sure you blow the brake lines/hoses out; don't want any junk getting into your fresh calipers...
      • ThrottleJunky
        • Jan 2011
        • 183
        • PNW
        Will do guys. I will go completely through the entire brake system. I'm kind of working my way through this thing. After the brakes are done I want to take it for a spin and kind of clean the motor out on the road- you know, the old Italian tune-up. I'm sure the front forks are going to need some attention, too.
        PS- Yeah, Phil, I found out about the spammers as I had a hard time registering. I'm happy to have been accepted.
        1980 XS1100G. Work in progress.
        1980 XS1100G. 2nd work in progress.
          #34
          Another thing to lol at is the steel line in the rear brakes can rust on the inside. Mine had clogged from rust buildup. Just something else to check.
          • ThrottleJunky
            • Jan 2011
            • 183
            • PNW
            #35
            Well, I completely rebuilt the front brakes, but I've run into a problem with the rear. It seems the piston is stuck on, and the wheel is completely locked up. I cannot pull the caliper off as a result. I have tried everything. Most of the fluid is gone. I don't know if I should pull the whole wheel off and try to deal with it, but it is frozen solid. Any suggestions? I already attempted the suggestions in the "brakes frozen" section.
              • 8797
              Did you remove the screw from the left side of the caliper that holds the pads in place? The caliper won't come off otherwise.
              07 Triumph Tiger 1050
              • ThrottleJunky
                • Jan 2011
                • 183
                • PNW
                #37
                I also found out the clutch is not disengaging when the cable is pulled. I took off the side cover, and the cable is actually pulling the lever up, so I'm a little stumped, but I'll delve into that after I finish the brakes.
                • ThrottleJunky
                  • Jan 2011
                  • 183
                  • PNW
                  #38
                  Yes, that was one of the first things I removed. The pads are just stuck on full because the piston is locked up.
                    • 8797
                    Well then, I'd remove the brake line and get a pry bar and go at it. Good luck!
                    • ThrottleJunky
                      • Jan 2011
                      • 183
                      • PNW
                      #40
                      I tried a pry bar and everything, and I finally just took a hammer and gently beat the crap out of it, and it finally came.
                        • 8797
                        Nice, now the fun part of getting the piston out. I've heard a grease gun works well for super stuck pistons.
                        • cywelchjr
                          XS-XJ Super Guru(Deceased)
                          • 4450
                          • Sacramento, CA
                          #42
                          Yeah, although if it was still hooked up and you could get fluid into the rear MC, that MIGHT work best, but from the sounds of how the system is that might be a long shot, but it would be the first thing I would try. Of course if the piston is that stuck, it might be too corroded to save.
                          • cowboybob998
                            • Mar 2009
                            • 371
                            • KC MO
                            #43
                            date code
                            Originally posted by ThrottleJunky
                            I should mention that I have not adjusted the fuel/air screws on any of the carbs. I did bottom each out, counting the turns, then returned them to their original positions. They vary wildly, from 1 1/2 turns out, to more than 3 1/2. I need to read more about synchronization before I get into fine tuning these things.
                            The brake system needs attention. The piston on the front brake control is stuck in, so I may have to rebuild the master cylinder. The fluid was absolutely vile. It was dark brown and chunky, so I'll bleed the system tomorrow. The rotors look excellent. The Dunlop tires were brand new but flat when I bought the bike. It's a shame but I think I should replace them for safety reasons. I'm just worried that the rubber has deteriorated.
                            check the date code on the tires, a branded 3 0r 4 letter code on one side of the tire, the last one or two numbers is the year it was made, they say dont run tires over six years old no matter what they look like
                            1979 xs1100 f
                            142 main, 45 pilot, Jardeen crosover 4/2, no air box
                            floats @ 25.7
                            1979 xs1100 F
                            1978 gl 1000 goldwing
                            1981 gl 1100 goldwing
                            !986 venture royale 1300
                            Just an ol long haired country boy, come to town to spend some egg money
                            when ya get bucked off, get back on
                              #44
                              Originally posted by cowboybob998
                              ....they say don't run tires over six years old no matter what they look like
                              'They' are lawyers, and that six year figure is correct if you live in Phoenix Arizona or a similarly hot sunny climate. If you live somewhere cooler and the tires haven't been exposed to the sun constantly, they can last considerably longer. Use your head; if there's signs of weather-checking, yeah, you should replace them, but just because they're six years old doesn't mean they're bad...
                              • cowboybob998
                                • Mar 2009
                                • 371
                                • KC MO
                                #45
                                i have run ol tires around town here when working on an ol bike, but i aint getting out on the hyway unless its got new tires on it, those date codes are a good deal in my book.
                                1979 xs1100 f
                                floats @ 25.7
                                1979 xs1100 F
