CARB DISSASEMBLY AND CLEANING *pic heavy*
    How about that 'oxi-clean' stuff you see on TV? That shows the guy dipping a penny in it and coming out shiny new, no rubbing needed....
    Heck, even regular Coke will do that!
    • lee_dutcher
      • Apr 2009
      • 822
      • mason city iowa
      never had luck with oxiclean....ill stick to brasso for the brass pieces... let them sit over nite and in the morning they will be silver...
      1980 gs1000g "stock"
      • foreda
        • 949
        • Southwest Louisiana
        Tobasco Sauce
        Good ole Louisiana Tabasco Sauce works too!!
        78 XS1100E Standard
        Coca Cola Red
        Hooker Headers
        1979 XS1100 Special
        1980 XS Standard
        2006 Roadstar Warrior
        • lee_dutcher
          • Apr 2009
          • 822
          • mason city iowa
          #34
          go some of that in the fridge...lol
          • foreda
            • 949
            #35
            Toabasco Sauce
            The Tabasco stuff is made and bottled in New Iberia La area which is real close to me. It really will make a penny shine!!
            78 XS1100E Standard
            Coca Cola Red
            Hooker Headers
            1979 XS1100 Special
            1980 XS Standard
            • lee_dutcher
              • Apr 2009
              • 822
              • mason city iowa
              #36
              UPDATE
              well i went a head and soak them in some dawn and boiling water.. came out looking great! sprayed compressed air thu the all the orfaces. found out #1 carb has a broken air needle...but cant get the tip to brake loose from the hole what to do.... pics
                #37
                Did you leave them on the rack? If so take them off and remove the enrichment circuit parts and clean in there as well. As well as the imulsion tube and the pilot jets, the pic shows them all installed still.
                • lee_dutcher
                  • Apr 2009
                  • 822
                  • mason city iowa
                  #38
                  S*it i forgot all about the enishent passages..oh well i go all winter to clean them again....and again....and again...lol. also the pilots are under the flat head screw right?
                    #39
                    That is correct.
                    • lee_dutcher
                      • Apr 2009
                      • 822
                      • mason city iowa
                      #40
                      thank you sir...KUDOS for the quick response.... now i need to find my thin flat head screwdriver
                        Make sure you have an exact fitting screwdriver, even if you have to grind one to the right size. It'll save you a lot of greif from stripping out those pilot jets. I've found the correct one needs the sides ground down to fit exactly down in the tunnel, leaving it as wide as possible. HTH
                        • lee_dutcher
                          • Apr 2009
                          • 822
                          • mason city iowa
                          #42
                          ground down an old stanley screwdriver and got them out... all we pretty clean except carb number one. that thing WAS all green and corroded and u can only see like 3 holes out of the possible 9( i think ) so i got all them together in there individual baggies lables 1,2,3, and 4 for and let them sit in brasso over night. oh and yes 42.5 mains across the rack. but ill need to get bigger ones to comp for the pods and exhaust
                            #43
                            Should only be 6 holes in the pilots. If there is more or less a PO put in the wrong pilots. There are other pilots that fit but are not correct and will mess things up, but your bike was running well before.....
                            • SFerinTEXAS
                              • Jun 2006
                              • 877
                              #44
                              I know someone asked before but I saw no answer, Did you pull the emulsion tubes? They do tend to crap up.
                              79SF
                              XJ11
                              78E
                              • lee_dutcher
                                • Apr 2009
                                • 822
                                • mason city iowa
                                #45
                                yes i did push out the emulation tubes. thats what i was talking about on my last post. srry i didnt specify
