I should have mentioned also that somebody could check my results on a in-bike installation by simply bypassing the bike electrics and spinning the motor by jumping off a running car/truck. Connect your ground, disconnect the starter lead from the solenoid and apply power directly to the lead...
Checking Compression...
Yep, can't leave nuthin' alone... -
In my humble opinion
A motor with no exhaust or air cleaner(Steve you mentioned you put a set of carbs on and retested) would allow a greater volume of air to pass through it.
I think this is the cause of the higher compression.
If it were my project I would take an engine that was within 10% do a clean up of the head lap the valves.
RickXS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
XS1100SG Project bike
http://s910.photobucket.com/albums/a...t=DSCF3034.jpgComment
If the carbs add no appreciable restriction at cranking speed the exhaust and air cleaner isn't going to add any either unless they are plugged. That's why Steve said I was right, as I contended that at cranking speed it wasn't pulling enough air for the carbs with the throttles all the way open wouldn't serve as any restriction to the amount of air the engine can move at that speed.A motor with no exhaust or air cleaner(Steve you mentioned you put a set of carbs on and retested) would allow a greater volume of air to pass through it.
I haven't ever noticed (on pretty much any vehicle) the air cleaner or exhaust to cause much if any restriction at idle either, but once you get up off of there they CAN become a factor.Cy
I see your point CY.If the carbs add no appreciable restriction at cranking speed the exhaust and air cleaner isn't going to add any either unless they are plugged. That's why Steve said I was right, as I contended that at cranking speed it wasn't pulling enough air for the carbs with the throttles all the way open wouldn't serve as any restriction to the amount of air the engine can move at that speed.
The more air you try to get the the greater the resistance.
Maybe Steve can test the 79 engine with the kicker?XS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
with my engine, when its cold
i get around 90psi compression,
with the carbs and exhaust fitted,
once its warmed up the compression jumps
up to around 150psi.
just had a quick look at my old text book
and it stated that
the engine should be fully warmed up and all
plugs removed before the procedure,
which is the way ive always done the test.Last edited by petejw; 01-13-2011, 09:27 PM.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
