cams
  • boediddly
    • Dec 2009
    • 50
    • columbus,oh
    cams
    does anyone know for sure, positively, 100% if the cams from an 78xs1100 e are the same as the cams from the 79 special? interchangeable?
    The '78-79 camshafts (both standard and special) are supposed to be identical, according to all available info (published specs, part numbers, etc). I'm not aware of anybody having an issue with interchanging these.
    The later cams are nearly identical, having less duration and overlap but slightly more lift on the exhaust valves. These will slightly reduce power if swapped for the early cams.
    • petejw
      • 2269
      • sydney australia
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • petejw
        • 2269
        • sydney australia
        yep the 78 and 79 cams are the same,
        was just comparing the early model cams to the later
        ones and noticed the holes for the oil gallery are slightly
        larger in the later cams.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
