Yamabond question......
  • brcree
    • Mar 2010
    • 388
    • S.C.
    The eng. is out....the cases are split, and my gears are changed out. OOOOraaaaaa!!!! Now its time to put it all back together, my question is: can Yamabond 5 be used instead if 4?
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    Well, they're not quite the same. Y4 is semi-drying and Y5 is drying. Might be tough to re-open the cases after Y5, but I've never used Y5 so its a guess.
    • brcree
      • Mar 2010
      • 388
      • S.C.
      yamabond
      Thanks Dav....I'll get some #4.
      At this time:
      1985 Goldwing Innr.
      2007 vtx 1300
      81 sx 1100 s h
      81 sx 400 special
        You DO want the #4. The "semi-drying" will expand and contract with the aluminum, and not leak. The #5 hardening will NOT expand and contract, and WILL leak.
        • brcree
          • Mar 2010
          • 388
          • S.C.
          Yamabond
          Thanks Ray....got it on order!
          At this time:
          1985 Goldwing Innr.
          2007 vtx 1300
          81 sx 1100 s h
          81 sx 400 special
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            Yamabond #4 is the same a Sudco threebond and Honda semidrying gasket sealer (aka Hondabond) but there are no subtitutes for Yamabond 5...
            These are 2 very different sealers and should not be interchanged. I find them both indispensable for what they do...
            Geezer
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              Three bond's 1104 liquid gasket is very close to Yamabond #4 and is easier to find. If your doing engine cases do them right with one of these 2 products. Apply this stuff exactly as instructed in the manual. Pay close attention to the areas around the O-ring for the oil pomp and around the crank bearings.
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                Three Bond's 1104 has been discontinued because it has lead in it. It has been replaced with 1194 which the same product, just a lot safer. So 1194 is a direct replacement to 1104.
                Larry
                82 XJ1100
                80 XS1100G (Project bike)
                64 Yamaha YA-6
                77 Suzuki TS-185
                • 79XS11F
                  • 3563
                  Larry
                  That's good to know for when I run out of what I have here.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • cywelchjr
                    XS-XJ Super Guru(Deceased)
                    • 4450
                    • Sacramento, CA
                    I've used the 1194 for the clutch cover with no leaks in well over a year now. Had to take it apart and put it back together several times as well in the first week or so and had no trouble with that.
