Cy is correct. The reason for the 'dip' is to reduce glare for oncoming drivers, so the low-beam cutoff is rotated slightly so it's lower to the left (unless of course, you're in one of those 'wrong side' countries, then it's rotated the other way
). Motorcycles lean going around corners, so there's no point in having it.
As far as using a car light on a bike, it doesn't make that much difference. You can see the difference, but unless you're cranking a hard left-hander you'll get pretty much the same light where you need it. I run a Cibie euro-spec car light in one of my other bikes, and it's much better than the stock one was....
). Motorcycles lean going around corners, so there's no point in having it. As far as using a car light on a bike, it doesn't make that much difference. You can see the difference, but unless you're cranking a hard left-hander you'll get pretty much the same light where you need it. I run a Cibie euro-spec car light in one of my other bikes, and it's much better than the stock one was....
I was able to locate a + wire in the fairing that is only used for the clock maintainer wire in my radio. I tapped into the ground circuit already there, and ran a test before actually installing it, and it fired as soon as the engine cranked. This time, the headlight stays on after turning off the engine too (as long as the key is still on), and doesn't flicker and turn off. The high beam works as it should as well, and there is a definite change in the beam spread when the hi/low switch is flipped.
