XJ1100 pilot screws.
  • mikej-t
    • Mar 2003
    • 13
    • Near Lampetr, Wales UK.
    Hi all,
    does anyone happen to know the part numbers for the XJ pilot jet mixture/adjusting screws?
    If so, it would be a great help....I need to order some and the supplier can't find them in the parts list.
    Many thanks,
    Mike.
    MikeJ-T.
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    Have a look on this link.
    http://www.cmsnl.com/yamaha-xj1100j-...list/B-05.html
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      The XJ uses the same version carb as the 80 and later XS models and you can get the idle mixture screws from MikesXS, just get the ones for the BS34 carbs which are what we have. He has kits that include everything related to the screws together.
      • mikej-t
        • Mar 2003
        • 13
        Thanks both for your responses. Much appreciated. Unfortunately the pilot screws aren't listed on the XJ parts diagram.
        If anyone can let me know the actual part numbers I'd be grateful.
        Many thanks again,
        Mike.
        MikeJ-T.
          • 3193
          If you go to this site you can find the part numbers as well as pics and which models will interchange as well. I use it a lot and I found it very easy to use as well. Below is the part numbers etc for XJ carbs, and the site address.
          11J-14105-00-00 is all the parts as a kit
          3H1-14147-00-00 is the O-ring
          3H1-14962-00-00 is the washer
          3F7-14134-00-00 is the spring, Air adjusting
          3L1-14923-00-00 is the screw, pilot
          • cywelchjr
            • 4450
            • Sacramento, CA
            I think that's because they are not available from Yamaha at any price. The XJ carbs are the same as the 81 XS1100 carbs, which the only two differences being the choke/enricher hookup and the jet sizes. Other than that, they use the same carb kits, and the same idle mixture screws. MikesXS has them, but I don't know the part number, but they are the only ones they list for BS34 carbs on his site (650's use the same carbs, just in pairs on the 80-84 models). They use the blunt tip mixture screws, and don't break off like the earlier carbs, but they can get stuck if cross threaded. They also have o-rings that usually need to be replaced, also available on the same site (they have kits with all those parts).
            • FJ111200
              • Oct 2007
              • 317
              Originally posted by mikej-t
              Hi all,
              Many thanks,
              Mike.
              OK Mike, try this
              NRP specialise in carburettor diaphragms, air cut-off valves [or coaster enrichment valves] carburettor overhaul kits and spares for all Japanese carbs.
              they are in Manchester and i've repaired various XS1100 and FJ1100/1200 carbs with parts supplied by him.
              Anyway, come over to us here, www.benefiscal.co.uk/forum we might be able to help and a bit closer to home.
              • mikej-t
                • Mar 2003
                • 13
                Thanks again everyone...
                it's always a pleasure to ask a question here... because I know I'll get helpful, friendly and informed responses...
                Cheers,
                Mike.
                MikeJ-T.
