Tear them down and build them up
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    Going to be a nice looking ride!
    Ken Talbot
    • daveyg
      • Feb 2009
      • 411
      • Boise, ID
      +1 that thing is gonna look damn fine!
      • petejw
        • 2269
        • sydney australia
        looking good,
        nice to see a change from black once in a while,
        have u decided on the colour of the tank and side panels?
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • the108penguins
          • Apr 2010
          • 130
          • Gainesville, Florida
          I've got a friend working on them right now. he does this for a living and is amazing with an airbrush. I decided to go with something simple so I'm having him do a 2 tone black top tank and fender with red sides and silver pinstripes. I think we're going to make the side covers black also but that could change. the black on the top will meet up with the seat nicely and the silver pinstripes should give it a bit more character. I'll post pics when I get them back on monday.
          79 XS1100 Special
          Kerker 4-1, Pods, BS34 old style carbs, plastic floats, 147.5 mains, progressive rear suspension (restoring)
          • the108penguins
            • Apr 2010
            • 130
            I am now at the last step of this re-conditioning and am working on the carbs. They are the older 78-79 style, I am having two problems.
            1. When I let go of the throttle the exhaust pops. I'm assuming that is because I am running a bit rich. I have 4-1 exhaust and pods I'm running 147.5 mains and my slide needles are on the middle notch. I am thinking about dropping the slide needles one notch to see if that helps as that should lean them out a bit right?
            2. I had a broken idle needle stuck in the #2 carb and the only way I could remove it was by drilling it out (I tried so many things) now the hole is 1/16th instead of 1/32nd how would you recommend I fill or adjust that back to the proper size? Or is it too much trouble as it does work I just have to tighten that screw all the way in.
            79 XS1100 Special
              • 8798
              Popping on decel usually means a lean idle mixture. Try turning the screws in a half a turn. You can try adjusting the needles but I have found the center position is always the best, YMMV. You should be fine with the enlarged hole for the pilot screw, it just might be a bit more sensitive adjusting. I've had to shorten the spring a little to get the screw to go in further on one of my bikes. HTH
                • 7765
                Also check that you do NOT have an exhaust leak. That is one more way to get popping on de-accel.
                  • 8798
                  Sorry, meant to say turn them "out".
                  • the108penguins
                    • Apr 2010
                    • 130
                    Whoo! I got my tank and rear fender back today.... AWESOME!!! really classic look with the two tone and pin-stripes. I can't wait to get it put back together. will post pics soon
                    79 XS1100 Special
                    • TADracer
                      • May 2006
                      • 1417
                      • Kenner, Louisiana USA
                      Yep, looks great so far. I like it!
                      If you still have the stock 42.5 pilot jets, go up one notch to #45's and re-tune/sync your carbs. That should cure your popping problem. If you are up to 147.5's on the mains you should be up one notch on the pilots anyway.
                      Mike Giroir
                      79 XS-1100 Special
                      • greatnw
                        • 177
                        Love the red frame! That is going to be a good looking machine.
                        Bothell, WA
                        1980 XS1100SG
                        • the108penguins
                          • Apr 2010
                          • 130
                          here are pics of the tank and rear fender at the painters.
                          79 XS1100 Special
                            OMG!!! He's polluting it with Harley parts!! I see that Sportster rear fender....
                            Just teasing....
                            Similar paint scheme to the first Sporty... I like it!
                            • the108penguins
                              • Apr 2010
                              • 130
                              It's a PO add-on. I didn't like the long dropped down fender look so I trimmed it up to where it is now.
                              79 XS1100 Special
                              • the108penguins
                                • Apr 2010
                                • 130
                                ok so I'm down to tuning it and I've got a charging problem. the four wire connector coming from the generator had melted and two of the connectors needed to be replaced. With that done I ran it for about 10 min and then it shuts off because the battery doesn't have enough charge to maintain the ignition module. After about an hour on a slow charger it's ready to start again and will repeat the earlier performance. Ideas?
                                79 XS1100 Special
