Needed Part
  • Iron Duke
    • Jun 2010
    • 74
    • Manhattan,Ks
    Needed Part
    Does anyone out there have or know of a source for a front air fork valve, complete or without cap(listed part # I have is 3H5-23190-00 / SB48). As I have one side that the threaded stem that the cap fits is twisted off and I can not use chuck to put air in shock.
    • 3193
    I may know somewhere to get it. I need some more info though. This is for a 79F right? I just found 2 new countershaft bolts from this supplier so he may have something like this as well. Front fork air valve when I punch in the number you supplied I get no matches but I get several under 3H3. Tell me exactly what yr and model it is and I will check it out. Usually takes a day or two before he replies though!
      I'm sure I got one of those threaded air valves hanging around. You have a Standard correct? The Specials and Standards are different thread size.
        Iron Duke, I got both kinds. One uses a 14MM wrench to remove, the other type, a 10MM. Shoot me a PM with your address and I'll send it to you. Let me know which type.
        • Iron Duke
          • Jun 2010
          • 74
          • Manhattan,Ks
          Air valve
          Takes a 14MM wrench, so's that a standard ? thats what I got, but these are replacements for an ol warnout pair,seems that the springs are 2-3" shorter on the air shocks , but both are follow mounted,and look same side by side.
          • Iron Duke
            • Jun 2010
            • 74
            • Manhattan,Ks
            air valve
            Yes its a 79F,Could be 3H3, but do the rest of the numbers match up ?
              Yep, 14MM is a Standard, you must have 80-81 forks on there because the 79F had just preload adjustment, no air.
              • Iron Duke
                • Jun 2010
                • 74
                • Manhattan,Ks
                Air shocks
                Thanks for the Info Phil, didn't think thay had air on the seventynines, I'll try to keep the coolldd air up here in the flatlands....Thanks again, Hope you and yours have the best Xmas ever. And happy new year. the Duke
                  No problem, have a Merry Xmas and Happy New Year. Peace
