80 Special Exhaust Question
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Originally posted by Kit
    Finally got those exhausts, though it turns out they're both from a '79. The left side has quite a bit of rust, but the right side isn't too bad. Both have a few small dents here and there.
    So, now I have 2 questions:
    1) What is the best way to go about cleaning up the rust without stripping off the chrome in the process? Or is that even possible?
    2) How are the pipes supposed to connect in the center? Should there be a clamp or something else that I don't have?
    And now, some pics for your viewing pleasure...
    I have had some pretty good results using noxon, and polishing compound. I would hold off on anything really abrasive till you commit to refinishing them.
    I was surprised how a lot of chrome on my bike came back.
    A polishing wheel on a drill might help.
    Rick
    650SF
    XS1100SG Project bike
      On the exhaust crossover, there is a gasket sleeve that goes on the right side pipe that slides into the left as well. Then the clamp goes around it. I may have a couple of those clamps in the garage.
      • Kit
        • Nov 2010
        • 201
        • Oregon
        That would be cool, thanks. I'm not seeing any of those sleeves on eBay. Anywhere else I might find one?
        XS1100SG - Obsession
        Like I told my last wife, I says, "Honey, I never drive faster than I can see. Besides that, it's all in the reflexes."
        -- Jack Burton
        • tinman905
          • Aug 2007
          • 946
          • Orangeville,Ontario ,Canada
          You can find the gasket from many places ,Parts and more, Mikes XS ,just use a pipe clamp or a muffler clamp if you can't find a stock clamp .
          BDF Special
          • Kit
            • Nov 2010
            • 201
            • Oregon
            Looks like MikesXS has one. So that gasket for the 650 is the same as the one for the 1100?
            -- Jack Burton
            • Kit
              • Nov 2010
              • 201
              • Oregon
              I had a "Doh!" moment earlier today. There's 2 of 'em on the exhaust that I'm taking off the bike, so I'll just use one of those.
              -- Jack Burton
              • Kit
                • Nov 2010
                • 201
                • Oregon
                Originally posted by natemoen
                Could always go for ceramic coating!
                Yup, the thought crossed my mind. I'm planning to call around this week to find out who does it around here. Get some quotes on both that and re-chroming.
                Just got a rough ball-park quote for $375. That includes prep work and 2 coats of the chrome-like finish.
                -- Jack Burton
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  By looking at the pictures, you'll need both of them. The spot where the #2 pipe meets the collector needs a clamp too.
                  • Kit
                    • Nov 2010
                    • 201
                    • Oregon
                    You're right, good catch. I really need to drink more coffee or something...
                    -- Jack Burton
                    • Kit
                      • Nov 2010
                      • 201
                      • Oregon
                      In my search for exhaust gaskets, I've come across 2 different kinds. One kind appears to be metal (don't know if it's steel or aluminum or something else),
                      http://cgi.ebay.com/ebaymotors/ws/eB...m=230568807758
                      http://cgi.ebay.com/ebaymotors/ws/eB...m=380306155656
                      and the other kind seems to be a softer crushable type.
                      http://cgi.ebay.com/ebaymotors/ws/eB...m=360338314834
                      http://cgi.ebay.com/ebaymotors/ws/eB...m=160530608107
                      Does it matter which is used? Are there any notable advantages and disadvantages between the two?
                      -- Jack Burton
                      • Tarheeltriple
                        • Dec 2010
                        • 52
                        • Eastern NC
                        Those pipes are not bad, see the attached post
                        to show how to clean them up.
                        Salty dog
                        Eastern NC
                        XJ-1100 Naked Boy
                        • Kit
                          • Nov 2010
                          • 201
                          • Oregon
                          Yup, already started that. Discovered that my annode is too small for what I'm trying to do, so I have to change my setup a bit come payday.
                          -- Jack Burton
                          • Tarheeltriple
                            • Dec 2010
                            • 52
                            • Eastern NC
                            (Discovered that my anode is too small for what I'm trying to do)
                            If she told you that, remind her that size is not to suppose to matter.
                            Salty dog
                            Eastern NC
                            XJ-1100 Naked Boy
                            • Kit
                              • Nov 2010
                              • 201
                              • Oregon
                              OK, here's the pics of my first attempt at electrolysis.
                              This is my initial setup. As noted in the other thread, my annode is too small for that size part, but I didn't know that at this point.
                              After 30 minutes:
                              After 1 hour. Not much happening.
                              After 11 hours, and not a lot of progress, I got a bigger piece of steel.
                              After 1 hour in the new setup:
                              After 3 hours:
                              At this point, I flipped it over and did the back end, but it was late and I forgot to take pics. When it was done, I hit the pitted areas with silver paint, wiped the paint off the chrome leaving it only in the affected areas, and let it dry under a heat lamp overnight. This is the next morning:
                              After 2 hours of chrome polish/buffing:
                              They didn't turn out as well as I would have liked, and the chrome polish I used (Mother's) didn't shine them up very well. But I think they're about as done as they're going to get. This is only a temporary solution until I can afford to get them ceramic coated.
                              -- Jack Burton
                                Doesn't look too bad!
