airbox mods
  • gja
    • Dec 2010
    • 3
    airbox mods
    drilled airbox ,any photos about. new member, 1980 xs1.1 G .Owned from around late 92 ,farts about around 4-5 grand ,any tips ,4 in to 1 also.
    Post.this over on tje xs/xj tech forum. This area is for how to.do rings in the forums. Maybe a mod will see this and move it over for you.
      Hey there GJA,
      Just checked your Profile, says you have an 80SG, but in your post you call it an XS1.1 G? Are you outside the USA??
      Okay, I think I remember someone (?Scott/3phase) posting the airbox photos, but not sure and can't find. I did find a photo by Ken regarding another issue, but it shows the bottom of the airbox, the RECESSED area where the mounting screws are, and it's IN that area that you want to drill the holes, so that the air will be drawn up thru there and into/thru the filter into the surrounding airbox and finally into the carbs. IF you drill outside that recess, you'll be providing UNFILTERED air to the carbs/engine!
      That aside, you say you've OWNED the bike since '92. You have 4-1 pipes, but still the stock airbox. What maintanence have you done to the carbs? Have you done any rejetting?
      Any better description of it's performance besides "FARTS"? Are you able to get thru the 5krpm mark and have it rev on up to redline okay, or does it just run out of power and won't rev above 5k??
      Lots of things can contribute to loss of power, electrical, fuel, etc.!
        Drilled air box....
        Cut off snorkel....
        • gja
          • Dec 2010
          • 3
          thanks for the airbox tips, live in worlds best country New Zealand [ Christchurch]. revs fine to red line 4-5 grand just its roughest spot. removed fuzzy crap from airfilter using uni filter foam ,much better.Some munter tried drilling jets in mid 90s,must check oneday to see sizes , thanks
          • gja
            • Dec 2010
            • 3
            jets drilled to 1.5mm, drilled airbox,4 into 1, free flowing airfilter,mixture screw 3 1/4 turns out [ to stop popping on throttle backoff ]. the xs has never run so well or reved so freely. Now must work on better stoppers
