Rack-O-carb dimensions...
  • TomRodgers
    • Jun 2008
    • 492
    • La Porte Indiana
    Going along with the ultrasonic cleaning thread.....
    Im at work now with no access to my carbs...anybody able to get me some dimensions of XS11 carbs?? How long from side to side, top to bottom, front to back WITHOUT boots...
    Thanks!!!!
    4:1 Jardine w/ headerwrap
    Windjammer(wiring issues)
    New paint/brakes to come!!
    '80G FrankenBike (parts bike)
    '80G to fix "BlackSunshine"
    Stock Pilots/125 mains
    Pod filters; 4:1 Kerker??
    SS Brake lines w/ new M/C's
    LED Brake Lite
    Needs paint....
    13x6.25x5 give or take a quarter inch
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      Thanks!!! checkin out ebay for Sonic cleaners.....****load of them way better quality than HF for just a tad bit more $$$$....just have to do one side, then flip over....2 carbs at a time....no biggie!!!!
      LED Brake Lite
      Needs paint....
        The 6.25 is top of the cover to bottom of the bowl so you could probably knock almost 1 to 1.5 inches off that measurement.
        • 81xsproject
          • 3185
          • Fortuna, CA
          One thing to remember with USC's is that because of wave building and canceling, there will be areas within the bath of higher and lower 'activity.' I bring this up mainly because you want a little room to move them around in the bath so that nothing gets missed. I also recommend getting one with a heater. Or, you could do like I do and preheat the solution before you put in in the USC. Not only with the solution itself dissolve gunk better warm, but cavitation is more efficient in a warm solution. And if that is not TMI, I have also read that cavitation is more efficient in solution that has less gas dissolved in it (another feature of a hot liquid). PS you are going to be amazed when you pull those things out of the bath (SO shiny before oxidation dulls them again).
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
          • TomRodgers
            • Jun 2008
            • 492
            • La Porte Indiana
            I know this has been talked about before, but what kind of juice to use? how much of the rubber will i have to remove before dunking?
            LED Brake Lite
            Needs paint....
            • 81xsproject
              • 3185
              • Fortuna, CA
              Recently, I thought very seriously about using the USC in combination with yamaha's new carb dip stuff that you dilute with water. But, then I thought that as well as Simple Green works, why bother.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • Giggity
                • Mar 2009
                • 113
                • Longmont, CO
                Can Pine-Sol be used in the USC? Also, with Pine-Sol, do you need to remove the rubber diaphragms?
                1979 XS1100 Standard
                Putting it together........
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  Never tried it. Sure would be some nice smelling carbs, though. Another thing I read which seems worth mentioning , is to never use anything flammable in a USC.
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                  • yamtom
                    • 275
                    • Midland Michigan
                    pinesol use
                    Hi,
                    Ive had great luck with pinesol on the last three sets of carbs that Ive done. The racks remained intact, just dunked in a plastic tub. As many soft parts as possible removed, but three of the enrichment plungers remained with the rack. No usc used at all. I left them in for at least a full day.
                    Bikes Now.
                    80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
                    79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
                    83 Yammi Venture with custom footboards, 20k miles.
                    83 Yammi Venture parts bike
                    99 Valkyrie shield and bags 37k miles like new
                    08 ZX 14 Kawa Ninja 6k miles Sold
                    • Aches n Pains
                      • 349
                      • Reston, Va.
                      I did two sets of carbs with Pine Sol and it worked great. Need to be very careful to wash it all off or it will corrode parts that aren't aluminum like the choke slide. I washed with a hose and then blew with compressed air to get all the Pine Sol out. Did that several times.
                      1995 KZ100P
                      Pods, jets, pipes, cam adjuster, oil cooler
                      1977 Ironhead - custom build
                      Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                      Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
