Ultrasounding carbs
  • KA1J
    • 664
    • Groton, CT
    Ultrasounding carbs
    What's the benefit to ultrasounding carbs that are clean on the outside.
    Is there any benefit that ultrasounding will do to the lines inside the carb that can't be dealt with by carb spray & an air gun?
    Thanks
    • 8963
    The USC will vibrate loose crud that sometimes spray and air won't remove. This is if you have a good USC, the Harbor Freight ones aren't worth a dam, JMHO.
      The ultrasound causes cavitation in the liquid which helps to clean out the passages by the little bubbles knocking around.
        I've got a HF unit, and while it isn't the best I've ever seen, I think it's adequate (that old 'you get what you pay for' thing..). I have noticed that the more parts you load in it, the less effective it seems to be. One thing the USCs have over conventional cleaning methods is you can use cleaners that aren't harmful to rubber products in them and they still work fairly decently. Really crusty parts I'll pre-clean in solvent (paint thinner) before running them in the USC. The biggest problem with the HF unit is it's rather small tub size.
        • Woof
          • Jul 2010
          • 29
          • Plano, TX
          Running RXP through the fuel system a few times a year and there isn't any crud to clean, cheap insurance IMO.
          • 81xsproject
            • 3185
            • Fortuna, CA
            While doing some research on the subject I read that, while not a 100% definitive test, a decent USC should physically deteriorate a piece of aluminum foil. I know the one I use will. I put my hand in it ONCE to see how powerful cavitation could really be. Needless to say, it hurts pretty bad.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
              • 8963
              I am going to try that with my Harbor Fake USC with the aluminum foil, not the hand.
              Hmmm, maybe try a little chlorine in there...
              • latexeses
                • Jun 2008
                • 1491
                • California
                81xsproject
                I had a pretty high powered sonic cleaner until it was lent and got burnt up.
                Anyway I ran my hand in to pick out a part and it stung every joint in my hand that had arthritis!
                I sure remembered where those beat up fingers were!
                I ran the SF carbs through that thing I thought they were pretty clean. Was I ever wrong. There was crud running out of every hole in the carb body. The bottom of the tank looked like I cleaned a pair of boots. Thats an exaggeration but it sure got junk out of there that I would have bet wasn't there.
                Worth having if you can afford a better one.
                Everything on hold...
                • Aches n Pains
                  • 349
                  • Reston, Va.
                  Interesting video of ultrasonic cleaning
                  1995 KZ100P
                  Pods, jets, pipes, cam adjuster, oil cooler
                  1977 Ironhead - custom build
                  Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                  Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
