Do any of you guys know if the harbor Freight o-rings, the kit that comes with the red backing, are gas proof? Has anybody had any problems with these? would like to use them in a set of carbs.
Harbor Freight O-Rings
O-rings can be made from lots of stuff, but the Viton ones are fine for fuel. I'm sure others are fine too, but since the needle valves are viton-tipped...
-H. Ford -
I'd be a bit hesitant to use the HF ones, as HF quality can be pretty uneven. I think I'd try the autoparts store or a hydraulic supplier first...
But they may be fine; if you go for it, let us know...Fast, Cheap, Reliable... Pick any two
I have never had a problem with either the rubber or the viton o-rings from hf. Granted what I have used them for none of the o-ring (expensive or cheap) lasted long just due to the amount of friction wear on the parts. But the hf one lasted pretty much the same as the expensive ones.Nathan
Theodore RooseveltComment
I'm not sure if they will be the right size. You need metric o-rings and they are not easy to find in small quantities. Check out cycleorings.com for carb o-rings. He's a suzuki guy but the BS32 carbs take the same rings between the makes. I have bought from him twice and he's a stand up dude.US Army 1986-1991
1979 1100 Special (on the road after 16 years!)
1983 GS300L (wifes ride)
1985 Super Glide
2012 Super GlideComment
Hf has metric and standard sets.Nathan
I too have had good luck with both the nitrile and viton o-rings from HF. I don't know what goes into viton, but even at HF they are relatively spendy.I have never had a problem with either the rubber or the viton o-rings from hf. Granted what I have used them for none of the o-ring (expensive or cheap) lasted long just due to the amount of friction wear on the parts. But the hf one lasted pretty much the same as the expensive ones.'81 XS1100 SH
Sep. 12th 2015
RIPComment
In the absence of viton, nitrile performs just as well in my experience.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
Does anyone have the URL for these O rings?
Thanks,
Aches n Pains1995 KZ100P
Pods, jets, pipes, cam adjuster, oil cooler
1977 Ironhead - custom build
Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.Comment
The ones we are talking about are from here http://www.harborfreight.com/ just search for o rings.Nathan
I use them primarily to replace the o-rings in the float valve seats of 80s carbs. In my observations of dozens of carb sets, the seats on the 80's don't wear. So, it saves my customers a little money just replacing the valve needle and the seat o-ring. However, I have also used them on leaking fuel inlet t's.'81 XS1100 SH
Sep. 12th 2015
RIPComment
-H. FordComment
O'ring 101 here.... http://www.allorings.com/material_selection.htm and here ..... http://www.marcorubber.com/materialguide.htm1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
