I thought the steering head was the separate balls. Guess i was wrong. I will pull them apart and check, clean, and just reach them then. Thanks Steve.
The Fun Begins
Theodore Roosevelt -
I think Yammy only used the ball steering head bearings on the lighter bikes; I know the XS/XJ650s used these. But the 750 and larger bikes all got tapered bearings AFAIK; for sure the 11 did.
The only tapered steering head bearings I've ever replaced were from rust damage. You will run into some that may be discolored even after cleaning, but as long as they're not pitted and spin smoothly, they'll be fine...
I'm really big on Ziplock bags, the ones with the plastic button that zippers. I just disassembled my carbs and everything is in its own marked container & it's easy to see.Ever thing I took off I wrapped the bolts (hopefully to all be replaced with SS though) in tape and labeled what they were for and everything is in ziplock bags labeled with what it is.
So no I probably will still be on here asking "what the heck is this and where does it go?"
82 XJ1100 Maxim "hurricane"- DEKA EXT18L AGM battery , NGK BPR6EIX spark plugs, Green Dyna coils, Sylvania SilverStar Ultra H4 bulb, 139 dB Stebel Nautilus air horn, Home-made K&N air filter based on an original paper filter frame, new piston rings, Barnett Clutch Springs, SS braid/Teflon brake lines, TKAT fork brace, rebuilt calipers, master cylinders, new brakes, reupholstered seat, lotsa little things and so many answered questions here.Comment
That's what I thought too! I bought a new set of roller bearings for it and was a bit surprised to find roller bearings already in there when I finally took it apart to replace them. "Thankfully" (?), the original bearings where notchy, so I had to replace them anyway, so it wasn't wasted money.
Of course, if I had actually taken the stem off and cleaned and lubed these bearings some time in the 21 years I have owned this bike, there is a good change the bearings would have been fine... And I would have KNOWN it has roller bearings stock!-- Clint
1979 XS1100F - bought for $500 in 1989Comment
I haven't really been doing a goos job of keeping this up to date but oh well.
Finished with the engine covers today. Sprayed them with a few coats of ceramic black and then a few coats of ceramic clear. I then painted the yamaha on the alt and timing cover and then filler in the gear selector, made in Japan, kick start, and oil 3000cc recesses with the same yellow paint I am going to be using on the rest of it. After the yellow dried I lightly handed the recesses to get the.paint off the words but still leave the black underneath so that the words were black on a yellow background. Then I cleared them again. Didn't work perfectly but its ok.
Theodore RooseveltComment
Nice work Nate. Looks very nice. Now I am interested to see the rest of the color scheme come together.
78 XS750Comment
It's not going to be anything special. Side covers, tail, and tank will be the same yellow and then knee insets will be black. Not doing anything else with the engine right now.Nathan
Nate: Lookin really cool! Can't wait to see the finished product!Tom Clisham
Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
_____________________________________________
'78xs1100E ,all stock & original GONE TO WISCONSIN
'80 SG Vetter fairing,hard bags,trunk,fork brace,
stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCEComment
looking really good nate.
hows the engine rebuild coming along?pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
I have been putting off doing the ring gap filing.Nathan
lol
u and me both.
pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Those covers look good, Nate! Now all you need is matching strips and lettering for your gear that says: Helmet, Boot, Glove, Jacket.
♬Comment
I'm not going that far!
Ah come on Nate. Don't you WANT to go too far instead of just far enough?
